Good or Bad Idea...
Old Jun 12, 2001 | 03:11 PM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
Good or Bad Idea...
Would Anyone be interested in a web site that would be a free for all exchange for their PROM data??? IE have all stock PROM data, and have people submit & share their modified working PROM information.
Or does this already exist and I have not found it??? This would be a free service...
87 Formula 5.1 converted to TPI Yellow/Black
SLP cam, headers, cat-back exhaust
Ported & polished TPI intake
Gil Younger (no yo-yo) Shift Kit
Aluminum Driveshaft
3.73 Posi gear
Baer 12" brakes 4 wheels
KYB AGX Adjustable Shocks & struts
Hotchkis strut tower brace
South side machine frame connecters
Custom reinforced control arms and pan hard bar.
Custom Leather interior
87 Formula TPI (5 Speed) Yellow/Gray STOCK
1967 Buick Riviera 430hp Turns high 14's (Not bad for 4300 lbs)
83 Camaro (Parts)
83 T/A (parts)
http://www.3rdgenformula.com
Old Jun 12, 2001 | 04:22 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
<font face="Verdana, Arial" size="2">Originally posted by okfoz:
</font>
It's down at the moment but it already exists, at DIY_EFI.ORG
I would strongly recomment NOT sharing DIY bin files, once you get to customing a chip really well for a specific combo., it's about useless for anyone elses combo.. I been down the slippery slopes of that before. that and it gets way from DIYOURSELF. Short cutting the learning curve will make for lousy learning.
There are just so many things that interact, that you can get in wayyyyy too much trouble too easy coping or even using part of someone else work.
Old Jun 12, 2001 | 11:12 PM
leirch's Avatar
Listen to what Grumpy has said.
Although you have a GREAT idea. Copying somebodies bin or even going over their tables may "help" but you don't know why they did what they did so your basically looking at hyrogliphics(spelling?).
I tried to use Mike Davis's latest bin. It worked fairly well right off his page but came to find out that i was wasting time. I used some of his values(maybe 10% of them). I basically ended up by going back to a stock 90vette chip(copying those tables and then tweaking them from their).
Brendan
1987 IROC-Z L98,SuperRam,EB 6085's,LPE 219/219 Roller, Crane 1.6RR, EB TPI Base, 58mm TB, ADS 24#, AFPR, K&N, EB TES, Catco Cat, 3" Borla Cat-Back, Accel cap,rotor,distro/other crap, MSD 6AL, MSD Blaster 3, Aluminum DS, 94 Disk Rear, Adjustable Valve, Precision 3.73 Gears, Sub-Frame Connectors, Hotchkis Lower Control Arms, KYB Shocks/Struts, Suspension Techniques Lowering Springs, Polyurethan Bushings all over the place, Moog Upper/Lower Ball joints and Tie Rods ends/Idler Arm,
To see the ROC, Check out the webpage Here
Old Jun 13, 2001 | 08:10 AM
okfoz's Avatar
I was wondering about that, it does seem to make sense Is there a place for all the "Stock" values, and possibly the Hyperchip, Jet & other BIN's as well???
Okfoz
Aluminum Driveshaft
3.73 Posi gear
83 Camaro (Parts)
83 T/A (parts)
Old Jun 13, 2001 | 10:20 AM
85MikeTPI's Avatar
Car: 1985 Camaro Z28, VIN F
Engine: 427 sbc, HSR
Transmission: T-56, self rebuilt 700+ hp
Axle/Gears: Moser 12bolt, 3.42 trutrac
I started archiving stock TPI bins by broadcast
code (BCC) instead of by ECM type like on
the DIY archive. It's not the greatest
list, but its a start.
http://www.eecis.udel.edu/~davis/z28
(I won't archive commercial bins and don't
think they should be.. My motto is " Commercial
chip companies are in the business of selling
chips, GM is in the business of selling cars")
YMMV
mike
My Z28, ZZ4swap, TPI EPROMs
86IROC112
Apr 9, 2016 10:20 PM
ziggy89
Exterior Parts Wanted
Sep 10, 2015 08:44 AM
db057
Aug 22, 2015 08:17 PM
InfinityShade
Aug 22, 2015 08:00 PM
