Q on zif socket mem-cal in ECM
Old Jun 11, 2001 | 08:38 PM
james_fearn's Avatar
I soldered in the zif socket exactly as shown in the article using the same socket as well. When I try and install the z-f socketed mem-cal in the ECM the hold down by the zif socket will not completely close. I know this has been dealt with in a previous post but I was unable to find it. I think somebody ended up grinding down something but I hope it wasn't the latch in the ECM. I installed the zif correctly as shown in the article.
How can this be remedied?
James
1985 Z-28 305 TPI
165 ECM,STB,SFC,GW "wonderbar"
Old Jun 11, 2001 | 09:20 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
<font face="Verdana, Arial" size="2">Originally posted by james_fearn:
James
</font>
I always have to take an exacto knife and trim the ZIF Socket. Never had a problem after trimming.
Old Jun 11, 2001 | 09:43 PM
MikeT 88IROC350's Avatar
Car: 1988 IROC-Z
Transmission: 700R4 w/TransGo
Axle/Gears: BW 9-bolt w/3.73s
Yep, that is also what I did. I put the little lever on the ZIF that holds the EPROM in towards the center of the MEMCAL. That way it is not in the way. I also used a knife to trip the bottem and the opposite end of the ZIF, to help it fit better on the MEMCAL. The little folding clips on both ends of the MEMCAL will now clear everything. Also use some sort of glue under the socket to help hold it down.
One other little tip, always test fit the parts, before you make it permenant!!!
Best ET 14.413 @95.57 without
pulling valve covers or manifolds.
Also with stock 2.77 rear end!!!
Old Jun 13, 2001 | 10:31 AM
Mojo's Avatar
I removed the lever from the ECM.
408cid 1985 Corvette
http://www.mojosgarage.com
InfernalVortex
Apr 20, 2021 11:31 AM
Falcon50
Aug 22, 2020 03:26 PM
thunder57
Nov 7, 2015 02:28 PM
Jlanz55
Sep 29, 2015 08:55 AM
efiguy
Sep 27, 2015 01:30 PM
