I'm throwing in the towel!
Old Jun 13, 2001 | 07:04 AM
89vette's Avatar
I'll probably get banned for saying this but with my extremely busy work and family schedule, I don't have any time to work on my tuning. After the 7730 conversion running the 90 vette bin, the car runs worse that it ever did. VE tables are way off as expected. So I had a really bad day last Friday, called Formato and ordered a chip. Yes, Yes I know what you are saying. I have all the tuning stuff ie, Diacom, Tunercat, GMEPro, but don't have enough time with my limited experiance (just what I read) on speed density. If you knew what I paid for the chip I would definately be banished!
The other reason is that I have to get it inspected before the end of the month and I'm leaving for vacation of Friday for 10 days. If I take it to the inspeciton station with it runnign like it is now, I won't have a prayer passing PA smog.
I still hope to fine tune the Formato chip when I fin the time later in the summer.
Take care,
Jason
89 Six Speed FX3 coupe
More Performance 396cid specs:
Callies 4340 crank 3.875 stroke
Lunati Pro-Mod 5.85" rods
SRP Pistons 14cc dish
Comp Cams Custom cam 550 lift 220/229 duration
10.8:1 compression
AFR 195 competition ported heads
Miniram and TPIS 1 3/4" headers
Speed Density conversion in process
Old Jun 13, 2001 | 08:25 AM
leirch's Avatar
Jason,
Sorry to hear that you can't work on it. Atleast you are getting a quality chip. After you pass the smog tests you can get back into it. You won't be able to alter the Formato chip though. From what i hear , he switches some tables around or maybe its just the prom ID. To put a long story short. You won't be able to read the chip. Chris(TPI383) has one in his car, he couldn't read his.
I'd love to help tune your car if you were closer...
Brendan
1987 IROC-Z L98,SuperRam,EB 6085's,LPE 219/219 Roller, Crane 1.6RR, EB TPI Base, 58mm TB, ADS 24#, AFPR, K&N, EB TES, Catco Cat, 3" Borla Cat-Back, Accel cap,rotor,distro/other crap, MSD 6AL, MSD Blaster 3, Aluminum DS, 94 Disk Rear, Adjustable Valve, Precision 3.73 Gears, Sub-Frame Connectors, Hotchkis Lower Control Arms, KYB Shocks/Struts, Suspension Techniques Lowering Springs, Polyurethan Bushings all over the place, Moog Upper/Lower Ball joints and Tie Rods ends/Idler Arm,
To see the ROC, Check out the webpage Here
Old Jun 13, 2001 | 01:42 PM
TRAXION's Avatar
Car: 2005 Subaru STI
Engine: 153ci of Turbo Power!
Transmission: 6-Speed
Only takes one full day to get the lower and mid VE portions relatively close. Took me one day to get my 230/245 cammed MiniRam close (but will take a long time to be perfect). Formato's chip will yield BLMs that are more off than that one day of tuning. Wow. I do understand the 'time' thing though. But, definitely a huge HUGE waste of money. I wonder if the Formato chip will even have the Pump Shot where it needs to be. Hmmmmmmmmmm.
Tim
TRAXION's 1990 IROC-Z
Best Time = 12.244 @ 112.51mph (1.778 60' / 7.819@88.32mph in the 1/8)
All Natural. No Force. No Drugs. Stock Bottom End. Stock Body Panels.
Gunning for NA 11's with bigger cam, bigger stall, and bigger exhaust.
-=ICON Motorsports=-
Moderator: PROM board at thirdgen.org
Old Jun 13, 2001 | 01:58 PM
89vette's Avatar
Trax, I hear you. They told me they will keep re-programming the chip until I'm happy. They also demand Diacom files and claim they know all about Miniram's and pump shots and all its quirks since Jim Formato designed the intake. So it was one of those days where they said all the right things and made me feel better. A full day to get the VE's close? I honestly can say right now, I don't have a full day unless I can take a day off work, which I can, then ship the wife and kids off for a whole day to stay out of my hair. That's the hard part. BTW, I'm driving right through your town on Friday on my way to North Carolina. I'll wave when I go through!
Jason
Old Jun 13, 2001 | 03:48 PM
Greg '85 T/A's Avatar
Car: 1985 Trans Am/WS6
Engine: 5.0 TPI
"Discretion is the better part of valor!!"
Old Jun 13, 2001 | 04:05 PM
BOWTYE8's Avatar
Back when TTS was selling some of the first tuning software(grumpy you ever work with his) he would alter the chip tables as well . My bud used to be able to fix it for me to read other chips.
Dennis
85 vette,383,miniram,ZF6,4.10's..best ET 11.56@119.00 60' 1.59
w/100HP nirous 11.05@127
http://geocities.com/bowtie8
Fanatic1074
Oct 3, 2022 05:57 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
racereese
Oct 3, 2015 03:46 PM
Bigold4x4
Sep 28, 2015 05:21 PM
ndndndnd
Sep 28, 2015 08:00 AM
