Let me get this straight???
Old Jun 14, 2001 | 12:33 PM
Z28Man's Avatar
All I need to convert a 1988 ECM to a 1989 ECM is the 89 MemCal and a 89 PROM with VATS disabled??? I understand that the cold start injector will no longer be needed. Where is a good place to find a used 89 MemCal? Junk yards seem to sell the ECM without the MemCals??? Should I try to use the the 88 MemCal? Thanks for the help!
Old Jun 14, 2001 | 02:01 PM
Desert86Roc's Avatar
You have several options:
- You could reprogram your 88 memcal with the 89 code.
- or Keep your original as a backup, and purchase a new 89 memcal from GM, then change the programming
- or Find a used 88 or 89 memcal at a yard, and reprogram it the way you want.
- Find a used memcal on Ebay, or classifieds, and again, reprogram it.
If you use the 89 code, yes, you would disconnect your cold start injector.
I kept my original, and bought a second one which I modified. That way I always have a backup.
Mike Metzler (Desert86Roc)[*] Check Out:SpeedWorldMotorplex.com[*] Check Out:Chevrolet F-Body Online Part & Illustration Manual[*] My 86 IROC 305 TPI Page (406 build in progress)
ET's @ 1250 ft[*] 14.28 @ 95.461 mph (uncorrected, NOS, no headers)[*] 15.362 @ 88.238 mph (uncorrected, headers, no NOS)
[This message has been edited by Desert86Roc (edited June 14, 2001).]
Old Jun 14, 2001 | 03:02 PM
Z28Man's Avatar
Can I use a JET adapter with 89 code and use the 88 memcal? Then I can save my orginal code for backup, right?? Thanks!
Rousseau92maro
Feb 1, 2016 05:12 PM
1990FirebirdGTA
Sep 22, 2015 07:26 PM
R13_Braz
Sep 18, 2015 05:00 PM
FED 387
Sep 16, 2015 12:18 PM
TexasMaro
Sep 15, 2015 06:50 PM
