Tuning DF code [hybrid] [have datalogs]
Old Aug 19, 2006 | 01:51 PM
Sil's Avatar
Sil
Car: 1993 Pontiac Grand prix
Engine: 2.8/3100
Transmission: 4T60-E
Tuning DF code [hybrid] [have datalogs] help needed plz :(
hello everyone, im currently tuning my 1993 Gp
i rebuilt a 2.8 block/crank that i had in my old 88 cutlass before it got written off, so i pulled the motor and put it into my 93 gp, during the swap i installed a 3100 topend, rebuilt the 4t60-e transmission and changed the fdr to 3.73 and put in a 2800 stall Torque converter
the block has a comp cams 260H cam and the 3100 1.6 roller rockers.
i have all new sensors except tps, cts, iac and map which are all in good condition, so i have gotten as far as starting it up and getting some datalogs from it...
i usually hang out at 60degreev6, and posted my datalogs there, but im not really getting any help with my tuning :P so i come here, i realize this is an F body forum, but i have been reading this forum for a couple years now, and there are so many knowledgable people i thought i would try my luck here
so here are my specs...
i have disabled egr, and ccp and "calculate bpw at idle as function of airflow"
burnt the new chip installed and took logs
my cars specs
its a 1993 pontiac grand prix
9396 ecu running aubu df code
2nd gen 2.8L crank/block
2000ish 3100 topend (small runner i think)
port&polish heads
factory manifolds
comp cams 260H
1.6 rollers
has 496 lift
4t60-e 3.73
2800 stall torque converter
factory cat, and mufler (for now) gonna throw on the hooker muffler and put in a "test pipe" in place of the cat
im in canada so i dont have to worry about emissions
LOGS:
you can download the 3 i have are zipped
scroll down, click download for free
if the link or zip file doesnt work let me know and ill post up the csv's only
http://www.filefactory.com/file/c40ad7
there is an
idle@2000 rmp
idle
and idle in gear
Thank you
Dan
Old Aug 19, 2006 | 07:18 PM
Sil's Avatar
Sil
Engine: 2.8/3100
im pullin my hair out here....
lowering the values at 0%egr makes it run worse, raising them makes it run worse, i dunno...
Old Aug 20, 2006 | 03:51 AM
Mangus's Avatar
Car: '89 Trans Am WS6
Transmission: T5WC
Axle/Gears: 3.08 posi
Can you describe the problems you're having? Pointing us to logs is good, but it might help to have more specifics on the problem(s) you're trying to solve.
Old Aug 20, 2006 | 04:36 AM
RednGold86Z's Avatar
Car: 92 Form, 91 Z28, 89 GTA, 86 Z28
Engine: BP383 vortech, BP383, 5.7 TPI, LG4
Transmission: 4L60e, 700R4, 700R4..
Axle/Gears: 3.27, 2.73
I guess it looks a little rich at those loads (BLM 100-105, want to be about 128), and the IAC counts are a little high. And the spark advance is a little low at 2000 with no laod.
Anything else?
Old Aug 20, 2006 | 01:07 PM
Sil's Avatar
Sil
Engine: 2.8/3100
ya this things all over the place...
kpa at idle is 60+ at 2000rpm no load its like 35
im new to tuning so i dont really know where to start
i was talking to someone that said i should add all map related references from the df document into tunerpro
i found these (in DF document, and not already in df.xdf)
Code:
 0872        30     48 KIDFMAPH        28 KPA    MAP ABOVE WHICH CAN BECOME IDLE FUEL
                                                 FORMS HYSTERISIS PAIR WITH
                                                 KIDFMAPL
 0873        64    100 KIDFMPL       47.3 KPA    MAP BELOW WHICH CAN BECOME IDLE FUEL
 0878        78    120 KIDFMPH       54.6 KPA    MAP ABOVE WHICH CAN BECOME SPEED DENSITY
                                                 KIDFMPL
 0879        5E     94 KMPBPWFT        45 KPA    MIN MAP THRESH FOR RPMFILT/RPM BPW MULT
 08B3        40     64 KCELMAPH        40 KPA    HIGH MAP DETERMINES PART THROTTLE CELL
                                                 HIGH HYSTERESIS VALUE, WITH
                                                 KCELMAPL
looks like i might want to add this one for sure
seeing as im running 60 kpa at idle, everything is off balance
might want to raise this to like 70 kpa
i dont know the math to figure out the equation in tunerpro.
mangus, i would like to add the following references into tuner pro but need a little help
Code:
                                                 KIDFMAPL
                                                 KIDFMPL
                                                 KCELMAPL
0865 0260 608 KINJXBC5 0.2375 SEC/GM PRODUCT OF INJECTOR FLOW RATE AND
FUEL CALCULATION BASE CONSTANT
FOR SINGLE FIRE
i think this is a good place to start, adjusting the proper values for my injectors, first off to get them in the ball park
i have no idea what i should adjust these too
there should be 2 of them in df code for the adjustment of injector flow rates
only 1 is in tunerpro "injector flow rate"
this is in gal/h and is currently at 2.67, im guessing since im using the 3100 injectors there going to need to be adjsut alittle higher
same with
"0865 0260 608 KINJXBC5 0.2375 SEC/GM" once added to tunerpro is in grams/sec, and im guessing i should raise those to refelct values of the 3100 injectors
im thinking its a good place to start, to get the computer to see what its running for fuel anyways? :P
lol ????
MangusCan you describe the problems you're having? Pointing us to logs is good, but it might help to have more specifics on the problem(s) you're trying to solve.
ok, with 0%egr @ 224 (factory set) the car will start with no need to press the gas pedal, it will idle very bumpy and chuggy
pressing the gas pedal to rev the engine : from idle it will hesitate on tip in and then rev but with no power and it doesnt want to rev very high
or if i just tease it and tap the pedal it kinda just hesitates and the idles raises a bit then drops down, i notice the iac counts raise alot so im guessing thats why the idle raises a bit then goes down
when i put it into gear: it allmost wants to die, it will sit there and dance up and down up and down
now when i lower the 0%egr it does all this but worse x5
same with raising the 0%egr but noticable smoke from exahaust and it deffinatly wont idle and if it does idle it sounds mega plumpedy plump like alchohol funny car lol
i change it by like 10
the ecm wont take my 27sf512 chips, no matter what runs like its crazy rich, with smoke from the exaust, and i dont think it goes into closed loop i never ran it long becuase i dont want to wash out the rings or anything, like its super crazy rich
so i am using the at29c256 chips and i only have 1 left, my willems is eating them up for some reason
so this is why i am mega frustrated, and am looking for help lol
so to sum it up im trying to solve my rich problem of blms at 100
id like to adjust the injector values in the code to reflect the proper 3100 injector values, but i need to add it into tunerpro which i dont know how
sorry for the long post
Old Aug 23, 2006 | 12:28 AM
Sil's Avatar
Sil
Engine: 2.8/3100
well im thinking i have some sort of overlap false lean issue going on
i found some intresting refereces in the df.doc
0DD3 1C 28 KFO2DLT 0.124 VOLTS DELTA VALUE TO FORM RICH-LEAN
WINDOW FOR ADO2AF ("FAST O2")
0DD4 08 8 KHGTH 0.035 VOLTS MIN ERROR TO IMPLEMENT INT CORRECTION
0DD5 64 100 KIDOXTH 0.442 VOLTS RICH/LEAN O2 THRESHOLD WHEN IN IDLE
0DD6 70 112 KIDLZU 0.496 VOLTS ZEREFU VALUE WHEN IDLING
0DD7 58 88 KIDLZL 0.39 VOLTS ZEREFL VALUE WHEN IDLING
but they are not added into df.xdf(definition file), and im affraid i donot have the knowledge to add them properly
id like to try to lower the o2 mv constants @ idle and see if that will help correct my surging, stalling, and hesitation on tip in of throttle
anyone good enough at math to help me figure out what the "equation format" would be to enter into tunerpro
and are all these 8bit?
BumpaD82
Feb 26, 2016 02:57 PM
eustodp
Sep 20, 2015 05:09 PM
Reese-J
Sep 14, 2015 02:43 PM
3rdgenkindagal
Sep 13, 2015 02:02 PM
64Chief
Sep 12, 2015 08:05 AM
