RamJet Install...need to learn PROM stuff
Old Jun 17, 2001 | 03:19 PM
camaro6spd's Avatar
ok. I am printing out Traxions into to prom burning but I have other questions. Glenn91L98GTA told me when I install the RamJet I could keep the MAF setup(see TPI message board under "RamJet Setup..." He told me that I needed to disable the 9th injector and use a 89 ARAP BIN. Were can I obtain one of these and how much. umm....I am JUST starting to learn this stuff b/c I expect the TPI to RamJet Swap in a year and does anyone have any idea of what will be involved in programing this ARAP BIN? I will probably be here asking lots and lots of questions so bare with me. Thanks.
Old Jun 17, 2001 | 04:03 PM
camaro6spd's Avatar
ok, after reading Traxions artical PROM buring is basically a Spanish to English back to Spanish tranlation thing. Meaning that the Binary code(Spanish) is translated by the Programmer to "English" and then using the Editor to Edit it ina form we understand like, lb/hr, degrees C etc, then translated back to Spanish(BIN) with the Programmer and placed on the EPROM. SOOO....that mean that when I go to program it and lets say I have 24lb injectors that after translating it all I have to do is type in 24 ft/lbs?! or maybe a tempature. And you basically play with it untill you get it right.
Old Jun 17, 2001 | 05:20 PM
hectorsn's Avatar
Car: 78 Regal
Engine: 82 FBod LG4 305, 730 ECM
Transmission: M20
Axle/Gears: 4.10
How simple is it to burn an ARAP code onto a prom that didn't originally have it: obtain an ARAP.bin and burn it on to an empty prom. How easy is it to burn a prom that will work GREAT for your combination: spend lots of time tuning, just like any tutorial will tell you. Just telling the ECM that you have 24 lb/hr injectors doesn't do much. You have a long road ahead of you so keep on reading. That's why this is DIY, so you can learn the hows and whys. It can be as easy or as hard as you want it to be.
Old Jun 17, 2001 | 06:11 PM
JPrevost's Avatar
Car: 91 Red Sled
I like that Spanish to English thing. That's exactly how it is. The difficulty is all relative to time, starting point, and hardware/software. If you spend lots of time with it you will have great success. If you don't spend too much time (like me right now) you can get it to run 90% better than before. Spend more time and you'll get to 98% never 100!!
, Jon (350 TBI!)
91 Red My website
Old Jun 17, 2001 | 06:49 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
<font face="Verdana, Arial" size="2">Originally posted by camaro6spd:
ok. I am printing out Traxions into to prom burning but I have other questions. Glenn91L98GTA told me when I install the RamJet I could keep the MAF setup(see TPI message board under "RamJet Setup..." He told me that I needed to disable the 9th injector and use a 89 ARAP BIN. Were can I obtain one of these and how much. umm....I am JUST starting to learn this stuff b/c I expect the TPI to RamJet Swap in a year and does anyone have any idea of what will be involved in programing this ARAP BIN? I will probably be here asking lots and lots of questions so bare with me. Thanks. </font>
I'd suggest reading all the archived stuff I could find if I were you.
Each and ever engine in the world is unique, and combined with your driving style, makes things diffficult for what will work for your combo.. There is a tremendous abount of info here, just start at the beginning and read thru it. Then GMECM, as a min..
Information is Power
Takes Power to go fast
Old Jun 17, 2001 | 07:43 PM
camaro6spd's Avatar
oh yeah i understand that...but I thought it was alot harder to do then that before I new anything about it.
F.I. 57 Belair
Aug 23, 2021 01:09 AM
mcgarnicle
Sep 24, 2015 07:18 PM
RGB2015
Sep 20, 2015 09:26 PM
BLK87Z
Sep 18, 2015 11:29 PM
Winchester1094
Sep 15, 2015 09:48 AM
