getting rid of code 33
Car: 89 Iroc-Z
Engine: 355
Just wondering if there was an easy way to get rid of this code. Could I just raise the MAF vs RPM to max(255)? or would that just set a MAF sensor too low code? is there somewhere in the bin that I can modify?(if anyone knows the address it would be helpful). By the way it is 6E.
355 10:1 , AFR 190 heads, LT4 HOT cam w/ 1.6 roller rockers, complete Superram intake, 58mm BBK TB, 24# injectors, screens out of MAF, MAT relocated, March underdrive pulleys, Streetdampner, Crane HI-6 ignition, 160 thermostat, K&Ns, TES headers(Jet hot coated), Mufflex 4' cat back, B&M shift Kit, 2500 converter, and 3.27s. Chip is custom(doing it myself) Just got a 2 1/2 Harwood and soon to be painted.
<font face="Verdana, Arial" size="2">Originally posted by mike89z:
</font>
</font>
86 406
Car: 89 Iroc-Z
Engine: 355
So are you saying that I should get a new tdf from tunercat with a switch to turn off code 33? Im a little unclear on what your trying to say.
Guest
Posts: n/a
You need to change the MAF diagnostic table settings if there isnt another problem of some sort with your car. The table is easily accessible if you have tunercat. What is happening is its cross referencing the diagnostic table with the actual flow reading from the MAF and the actual flow is too low. I played around with this on the 32B code which has even worse settings than the 6E stock and got rid of the problem that way.
[QUOTE]Originally posted by mike89z:
[/QUOTE Basically, yes. Then you don't turn it off, you just increase the gm/sec. threshold for the code 33 to set.
86 406
86 406
<font face="Verdana, Arial" size="2">Originally posted by madmax:
[B]You need to change the MAF diagnostic table settings if there isnt another problem of some sort with your car. The table is easily accessible if you have tunercat. What is happening is its cross referencing the diagnostic table with the actual flow reading from the MAF and the actual flow is too low. B]</font>
