Looking for update on ARAP BIN. Does it turn on your electric fans ALL the time?
Old Jun 23, 2001 | 02:33 PM
Mark_ZZ3's Avatar
Car: 1989 Camaro-1LE
Engine: TPI(s)
Transmission: 5 speed (MM5, MK6)
Axle/Gears: 3.45, 3.73
I saw some posts a while back about a new tunercat $6E that offered a switch to allow us $32 guys to run the $6E without the eletric fans always going on. Something about the A/C input.
I recall my brother running a newer prom in his 86 and the fans would run all the time.
Just curious for an update. I am going to be buying Tunercat right away.
Mark.
Old Jun 24, 2001 | 12:27 AM
ZaphodB's Avatar
Car: Camaro IROC-Z '89
Engine: 350 TPI /w Procharger P1SC
Transmission: TH700R4 with Transgo shiftkit
Axle/Gears: 2.77 Borg Warner
<font face="Verdana, Arial" size="2">Originally posted by Mark_ZZ3:
Mark.
</font>
If you just get an untouched ARAP chip, then yes you're right, the fans would be ****ed up.
But use Winbin or Tunercat and change the flag for fan operation to normally open and it should work like it was intended to in your car....
If you just want to have something to start working on, here's the basic ARAP code with the fan control set to normal, versions both for vats and non-vats, 305 and 350....
http://www.area51.org.il/~zaphodb/gm...k-original.bin
http://www.area51.org.il/~zaphodb/gm...s-original.bin
Please note that this is not a finished performance chip, merely a starting platform to solve the basic problems you might encounter like different injector sizes between 305 / 350, the fan inversion flag...
I leave the rest of the work yo you, just trying to help out with some of the problems I myself encountered when I started out experimenting! If you download anything else than those four files, better ask what it is before you try to use it!
ZaphodB a.k.a Carl Andersson - zaphodb@faxancruisers.org
'89 Camaro IROC-Z 5.7L TPI - Mods under construction :-)
Custom ARAP Chip Under Development/180 t-stat, Edelbrock TES Headers,
SLP Airfoil, K&N Filters, Accel 8mm wires, Relocated MAT, AFPR @ 45 PSI
[This message has been edited by ZaphodB (edited June 24, 2001).]
eightsixseven
Dec 16, 2024 01:50 PM
RazorN8
Jan 7, 2022 11:44 AM
Ikes 91Z
Dec 9, 2015 03:49 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
