90d of spark at startup?
Guys,
The car in the Signature is running the P730SD setup. Wheneve i start it up from begin dead cold it bounces from the "correct" spark amounts up to 90d of spark and then back and forth for some reason, until it gets warmed up?
Am i running too lean or something along those lines?
Brendan
PS. I can send a diacom run to illistrate what i'm speaking of.
1987 IROC-Z L98,SuperRam,EB 6085's,LPE 219/219 Roller, Crane 1.6RR, EB TPI Base, 58mm TB, ADS 24#, AFPR, K&N, EB TES, Catco Cat, 3" Borla Cat-Back, Accel cap,rotor,distro/other crap, MSD 6AL, MSD Blaster 3, Aluminum DS, 94 Disk Rear, Adjustable Valve, Precision 3.73 Gears, Sub-Frame Connectors, Hotchkis Lower Control Arms, KYB Shocks/Struts, Suspension Techniques Lowering Springs, Polyurethan Bushings all over the place, Moog Upper/Lower Ball joints and Tie Rods ends/Idler Arm,
To see the ROC, Check out the webpage Here
Brendan
That's retarted timing or below 6 degrees base. Diacom displays it as a high number. For instance: If talking about timing from the reference at 6 degrees, if the timing is 5 degrees it will display a 90. 4 degrees would be 89 etc
RedLeader289
05-28-2019 01:47 PM
HoosierinWA
10-07-2015 10:15 AM
