85 sucks monkey balls
Old Jun 27, 2001 | 03:44 PM
IROC-Z_85's Avatar
85 sucks monkey *****
Hey guys,
I got one of them chitty 85's with the first/worst ecu. I called the GM dealer and they said i could get an 89 for $220 (Im expecting to do all the repinning) Is there a diff between 86/89. We dont have a close enough wrecking yard with even a TPI camaro, so is there a better place than the dealer to get one? Is $220 to much? Thanks!
1985 IROC-Z, nuff said :P
Old Jun 27, 2001 | 04:20 PM
gravitar's Avatar
$220 for an ECM?! Well, that is a dealership over-the-counter price, so I guess that isn't surprising. Anyway, I'm lucky enough to have abundant junkyard pickings near me, and I'd be happy to sell you an ECM for way cheaper than that. e-mail me if you're interested! ae2598@wayne.edu
Old Jun 27, 2001 | 04:24 PM
leirch's Avatar
Go read the ECM interchange article in the Technical Articles section. It lists different INTERCHANGBLE ECM's, that way you can go get a corsica or beretta ECM and not pay an arm and a leg, you will need the plugs also. Do a search on this Messageboard for the P730 or 165-->730 conversions, there is plenty already posted.
1987 IROC-Z L98,SuperRam,EB 6085's,LPE 219/219 Roller, Crane 1.6RR, EB TPI Base, 58mm TB, ADS 24#, AFPR, K&N, EB TES, Catco Cat, 3" Borla Cat-Back, Accel cap,rotor,distro/other crap, MSD 6AL, MSD Blaster 3, Aluminum DS, 94 Disk Rear, Adjustable Valve, Precision 3.73 Gears, Sub-Frame Connectors, Hotchkis Lower Control Arms, KYB Shocks/Struts, Suspension Techniques Lowering Springs, Polyurethan Bushings all over the place, Moog Upper/Lower Ball joints and Tie Rods ends/Idler Arm,
To see the ROC, Check out the webpage Here
Old Jun 27, 2001 | 04:31 PM
IROC-Z_85's Avatar
Well as far as ECM's from other cars, Im not looking for an ECM swapping project, Im just looking to be able to burn my own proms, which I can't with the 85...
I just need to find something comfortably under $200
Old Jun 27, 2001 | 04:35 PM
IROC-Z_85's Avatar
BTW,
I apologize if that interchange comment means that all those vehicles (165) also have interchanging plugs, if they do GREAT, if they dont.. Im going to have to get one from a camaro
Old Jun 27, 2001 | 04:41 PM
gravitar's Avatar
In fact, even ECMs other than the 165 have plugs that are interchangable. The '062, from 2.8 and 4.3 TBI S-trucks use the intentical plugs as the 165. Don't know if all the same pins are connected, but thats correctable at least!
BTW.. A good source of 165 ECMs are 4-cylinder '91-up S-trucks. Has to be Iron Duke motor though, the newer 4-bangers use a different one..
Old Jun 27, 2001 | 05:24 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
<font face="Verdana, Arial" size="2">Originally posted by IROC-Z_85:
</font>
You cna always try eBay. I've bought a number of TPI stuff from there. Just have to watch the bidding wars.
If you're changing ecms, do yourself a favor and go with the 730. Having one MAF die will cover all the expenses of the swap.
According to Some sources the 85 MAF is actually different then the 86-89, I've never tried that, just a headsup.
Old Jun 27, 2001 | 05:26 PM
IROC-Z_85's Avatar
Yea I believe the MAF might be different, thats why the 85 has that burnoff thing :P
Well do I need a 165 wiring harness too or can i use the 870 harness + repinning?
Old Jun 28, 2001 | 08:07 AM
Greg '85 T/A's Avatar
Car: 1985 Trans Am/WS6
Engine: 5.0 TPI
<font face="Verdana, Arial" size="2">Originally posted by Grumpy:
According to Some sources the 85 MAF is actually different then the 86-89, I've never tried that, just a headsup.</font>
They are the same. Good 'ol Bosch. Zero to five volts out. A number of people have upgraded to the '165 ECM and retained their '85 MAFs.
http://www.eecis.udel.edu/~davis/gm-eproms/ecm_swap/
-Greg
'85 Trans Am - WS6,TPI:
Original owner, original paint/engine/interior, plus the usual bolt-ons
[This message has been edited by Greg '85 T/A (edited June 28, 2001).]
Ed1LE
Sep 30, 2018 09:14 AM
Vintageracer
Sep 24, 2017 12:34 PM
loud91rs
Oct 5, 2015 10:05 PM
sjorgens
Oct 1, 2015 07:54 PM
3.8TransAM
Oct 1, 2015 07:47 PM
