A few questions with $88 730
Old Aug 26, 2006 | 07:27 PM
AM91Camaro_RS's Avatar
Car: 91 Camaro
Engine: 3.1...not hardly stock
Transmission: 700r4....not stock either
after my most recent cam swap, the thing is horribly rich at idle (plenty rich all around but especially at idle). tuner pro rt show " idle condition met" "false". what conditions have to met for that? is vacuum a large part of that? I'm sure that's part of my idling rich problem, the low vacuum. It only pulls about 5" at idle. How should I try to go about fixing that issue?
also, what conditions have to be met for the launch mode? Thanks!
Old Aug 29, 2006 | 09:54 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
To be in idle there is a TPS% and MPH qualifier. The TPS% usually needs to be below 1.5%, and the MPH below 14.
That will set the 'idle conditions met' bit. Maybe double check the ADS file. The idle status bit is in RAM $2A and is bit 7.
For the rich, lower the VE table.
There is a post on the $88 launch mode. Use 'launch' and then my username in a search, it should be found.
RBob.
Old Aug 29, 2006 | 03:29 PM
Car: 91 Camaro
Awesome, thanks for the help! I'll do a search for that post, too!
Edit: I forgot about that post. Its been a while since I've done anything with the tuning so I'm halfway starting over on what means what and all of that kind of stuff.
Azrael91966669
25
Jun 20, 2017 04:04 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
355tpipickup
Aug 19, 2015 10:02 PM
redmaroz
Aug 16, 2015 11:40 PM
