eager for some help
Old Aug 28, 2006 | 04:45 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
eager for some help
With this speed density, I am at a total loss, I have no idea where to start or anything.
I ran low 14's at the track with the combo in my sig the other day. 95mph.
I don't even know what is going wrong. I know it is all in the tuning. But where do I start? I have read everything over and over but I just don't get it. I think the main issue is my fuel injectors as everyone suggests so I would like to start with learning to properly lean it out.
Old Aug 28, 2006 | 09:50 PM
Z69's Avatar
Z69
You could start here.
http://www.catb.org/~esr/faqs/smart-questions.html
Old Aug 28, 2006 | 10:10 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Smartass
Old Aug 29, 2006 | 06:42 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
I guess I can rephrase my question, And ask, What's the best method for removing fuel from normal driving (or does the o2 do an ok job of that) and for wot, Should I focus on the PE vs. Tables?
Old Aug 29, 2006 | 08:59 PM
mike1986fyrbird's Avatar
Car: 1987 Trans Am GTA
Engine: 357ci Stealth Ram - Under Pressure
Transmission: Built 700r4/Pro Yank 3400 Extreme
Axle/Gears: 9-Bolt 3.27
Are you still adding the base distributor timing + timing table values thinking that equals total timing?
Lets see what your timing table looks like.
Old Aug 29, 2006 | 10:51 PM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
Try reading Trax's Tuning Article in the stickies up top
Everything you are asking is covered there.
Once u can explain to us what you are dealing with we can try and provide you with answers.
later
Jeremy
drumstixer
Sep 29, 2015 03:02 PM
IROCZ28KevinZ
Jun 21, 2009 03:05 PM
GerryCat09
Aftermarket Product Review
Apr 8, 2009 10:18 PM
Demon_Eater
Nov 4, 2008 09:55 PM
llvll4l2c91350
Jan 19, 2006 07:41 PM
