93 3.4v6 ECM question.
Old Jun 30, 2001 | 05:42 AM
leirch's Avatar
Guys,
I've found a 93bird for CHEAP, entire drivetrain is still good. It has the 3.4SFI v6, i'm going to try and find a decent 3rd gen with a v6 to do the COMPLETE swich over. I was wondering IF you can reprogram the 3.4 ecm and which definition would i need? Its an eeprom if i remember correctly, right?
Brendan
1987 IROC-Z L98,SuperRam,EB 6085's,LPE 219/219 Roller, Crane 1.6RR, EB TPI Base, 58mm TB, ADS 24#, AFPR, K&N, EB TES, Catco Cat, 3" Borla Cat-Back, Accel cap,rotor,distro/other crap, MSD 6AL, MSD Blaster 3, Aluminum DS, 94 Disk Rear, Adjustable Valve, Precision 3.73 Gears, Sub-Frame Connectors, Hotchkis Lower Control Arms, KYB Shocks/Struts, Suspension Techniques Lowering Springs, Polyurethan Bushings all over the place, Moog Upper/Lower Ball joints and Tie Rods ends/Idler Arm,
To see the ROC, Check out the webpage Here
Old Jun 30, 2001 | 07:44 AM
hectorsn's Avatar
Car: 78 Regal
Engine: 82 FBod LG4 305, 730 ECM
Transmission: M20
Axle/Gears: 4.10
I don't think it's a flash prom yet. That was 94 and it was a PCM. I don't know that there's a definition file for it though.
Old Jul 2, 2001 | 10:16 AM
leirch's Avatar
Anybody else have anymore info on the computer itself? Or would i be best off to go with a 3.1mpfi computer/intake setup?
InfernalVortex
Apr 20, 2021 11:31 AM
Falcon50
Aug 22, 2020 03:26 PM
thunder57
Nov 7, 2015 02:28 PM
Jlanz55
Sep 29, 2015 08:55 AM
efiguy
Sep 27, 2015 01:30 PM
