Need info on '85 ecm wire harness
Old Jul 4, 2001 | 08:58 PM
tntcorvette's Avatar
Ok...im lost on a couple of things here doing a '870 -> '730 conversion...
On the '85 ecm I have the following pins that are un-used and the Haynes manual is no help and the info I have seems to be insufficient.
B6 (vats)
B9 (N/C on the conversion info I have)
B11 (N/C on the conversion info I have)
B12 MAF signal
C1 Fan control
C7 (N/C on the conversion info I have)
C8 4th gear switch
C11 (N/C on the conversion info I have)
D4 EST Control
D8 (N/C on the conversion info I have)
D9 (N/C on the conversion info I have)
D11 A/C pressure switch
D12 (N/C on the conversion info I have...for this one it says for the '870 -> '165 it goes to A11 and then from the '165 -> '730 it says N/C)
Remember I am putting in a '730 ecm into a '85 L98 MAF car. I know vats has to be disabled so I will disable that when I burn my chip.
I got the info from the guy with the '85 Camaro's site and something seems to be missing in the '85 ecm diagram and '730 diagram.
TIA!
1985 355 S/R V8
[This message has been edited by tntcorvette (edited July 04, 2001).]
Old Jul 5, 2001 | 08:52 AM
Greg '85 T/A's Avatar
Car: 1985 Trans Am/WS6
Engine: 5.0 TPI
CHECK the '870-'165 conversion out. There's a slight wiring difference between the 'Vettes and F-Bodies as noted in the re-pinning.
-Greg
'85 Trans Am - WS6,TPI:
Original owner, original paint/engine/interior, plus the usual bolt-ons
[This message has been edited by Greg '85 T/A (edited July 05, 2001).]
crt454
Interior Parts Wanted
Jun 23, 2017 02:25 PM
TheJoeY88
Dec 31, 2016 07:30 PM
Reddeath210
Oct 6, 2015 08:20 AM
355tpipickup
Aug 19, 2015 10:02 PM
stalkier
Aug 13, 2015 12:59 PM
