Best way to copy tables from one bin to another using tunercat?
What is the best way to copy a table from one bin to another bin using tunercat? I know some people seem to do it quite easily but maybe I haven't looked in the right place.
James
James
Car: 2005 Subaru STI
Engine: 153ci of Turbo Power!
Transmission: 6-Speed
Load the BIN you want to change
Load a compare BIN that has the table you want
Bring up the table you want to change
Turn Compare ON
Highlight the whole table (click in top left cell and drag to bottom right cell)
Click the pencil toolbar button and it prompts you for a value. Use a value of ZERO ('0'). This tells tunercat that you want NO difference between your current table and the compare table.
This method works on most of the tables. On a couple tables (like the pump shot table) it doesn't work ... not sure why.
Tim
TRAXION's 1990 IROC-Z
Best Time = 12.244 @ 112.51mph (1.778 60' / 7.819@88.32mph in the 1/8)
All Natural. No Force. No Drugs. Stock Bottom End. Stock Body Panels.
Gunning for NA 11's with bigger cam, bigger stall, and bigger exhaust.
-=ICON Motorsports=-
Moderator: PROM board at thirdgen.org
Turn Compare ON
Tim
