Problem with TCC coming and going.
Old Jul 9, 2001 | 08:08 PM
MikeT 88IROC350's Avatar
Car: 1988 IROC-Z
Transmission: 700R4 w/TransGo
Axle/Gears: BW 9-bolt w/3.73s
I run my car over the weekend to a cruise-in and car show, over a nice hilly decent road.
One time I was in fourth going up hill about 60, and I noticed the TCC was pulling in and out, kind of like a surge condition. I know it didn't kick down to 3rd, since I manually shifted down and the rpm went up higher. I was giving it a little gas to maintain speed up the hill.
Amother time I was going around 50 up the hill and the TCC was also surging.
I have the TCC unlock prevent set at 60, and I lock/unlock the TCC in 4th at 50/45. Are these settings too high? I also noticed that GM had the difference between lock and unlock set at 2mph. This was consistent for many different bins. I don't think I hit the tables for unlock/lock for %TPS vs mph, since I didn't think I gave it enough throttle at those speeds. But I could be wrong since I didn't have my scan tool connected.
Today I scanned on the way to work, and no surge condtions were observed, so it seems to related to maintaining speed up hill under slight load.
Anyone got some suggestions? TIA
Best ET 14.413 @95.57 without
pulling valve covers or manifolds.
Also with stock 2.77 rear end!!!
Old Jul 9, 2001 | 08:17 PM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
I had the same problem with "rolling hills". I found the TCC locking and unlocking, along with the EGR kicking in and out (you may not have noticed that one).
I found locking my TCC at a lower speed (45 MPH) along with controlling my EGR differently to prevent this "enable/disable" made highway cruising on "rolling hills" much smoother. Try keeping the TCC locked and EGR functioning.
Old Jul 10, 2001 | 08:48 PM
Car: 1988 IROC-Z
That's kind of what I was planning on doing, just changing the TCC lock/unlock constants.
But what about that Unlock Prevent parameter? I understand it to be the value which the speed must drop below before the TCC can unlock. Hmmmm. So if I am set to 60, then below that the TCC can unlock? Guess I should lower that number.
I checked some recent scans, and I do believe the EGR is working. The duty cycle is flipping between 0 and 100%. I will most likely leave it alone for now.
Old Jul 10, 2001 | 11:22 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
<font face="Verdana, Arial" size="2">Originally posted by MikeT 88IROC350:
</font>
FWIW, also look at operating temp., vs TCC enable. A 156dF enable with a 160dF can be lots of fun to figure out.
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
</font>
Street Lethal
Apr 30, 2019 12:14 PM
jklein337
Sep 19, 2018 06:23 PM
Fronzizzle
Aug 17, 2015 02:52 PM
mizz0313
Aug 12, 2015 06:45 AM
