$60 WB02 patch
Old Sep 1, 2006 | 08:50 AM
ostrich's Avatar
Car: 85 Iroc-Z
Engine: 383, Vortech SQ
Axle/Gears: Stock 7.5 w/ shafts, 3:73
$60 WB02 patch
Using the $60 code and looking for a WB02 patch to run my wideband. I emailed Grunmpy, but haven't received anything. Just wondering if anyone has a patch for this? Let me know, thanks in advance.
Old Sep 4, 2006 | 07:27 PM
ostrich's Avatar
Car: 85 Iroc-Z
TTT Anyone???
Old Sep 4, 2006 | 08:24 PM
JP86SS's Avatar
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
You could do it the way I described in this thread.
https://www.thirdgen.org/forums/diy-...osed-loop.html
Since it is $60, I'm figuring you have source code and could easily slip in the same code with minor modification.
Just would need to verify the pin, channel, etc. you would connect to but the theory of operation would be ok.
Old Sep 4, 2006 | 10:08 PM
Z69's Avatar
Z69
I thought it had the DIY-WB patch in it already.
You might want to learn a little source code so you can tell if it's there
and how to make it work for your WB.
Old Sep 5, 2006 | 11:53 AM
1981TTA's Avatar
Car: 81 Turbo Trans Am
Engine: 301 T
Transmission: 200-4R
If we can get Grumpy's permission, I can supply the source code that supports multiple WB sensor transfer functions (see https://www.thirdgen.org/forums/diy-...band-code.html). This was originally designed to work with $58 and should be a pretty straightforward drop-in to $60.
Old Sep 5, 2006 | 07:43 PM
ostrich's Avatar
Car: 85 Iroc-Z
Guy's,
I'm not familiar with the source code etc. If it's the same as Dig's $58 WB02 patch with patcher.exe, I don't have a problem. If someone can tell what needs to be done in the source code & a little direction I'm willing to try?
Old Sep 5, 2006 | 10:55 PM
Z69's Avatar
Z69
Have a look at the link JP86SS posted and then ask questions.
You will basically delete some of the $60 WB code at a minimum.
BlueIroc-Z
Jun 9, 2019 03:22 AM
86White_T/A305
Aug 17, 2015 12:16 AM
spud
May 1, 2001 12:47 PM
Xenodrgn
Apr 25, 2001 09:36 PM
crazeinc
Feb 14, 2001 09:03 AM
