Pocket Programer won't program
Old Jul 5, 2001 | 04:11 PM
87ColdAirIroc-Z's Avatar
I finnaly got everything ready and i cannot get my pocket programer to program everything is see is set up correct. please help!!
87 Iroc-Z 305 TPI
Dynomax exhaust
modified MAF & airbox
3-10" JL subs
Eclipse components
Old Jul 5, 2001 | 05:17 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
<font face="Verdana, Arial" size="2">Originally posted by 87ColdAirIroc-Z:
</font>
First, thing is to see if the chip checks as erased. What series chip are you working with?. oem in memcal?.
Old Jul 5, 2001 | 07:45 PM
The chip is erased the PP confirms it. I am using a oem chip 27c128 i tried programing in 12.5v and 21v neither works. I also tried to use the fileprom and eprom programs in windows, a dos shell in windows and in straight dos, however i cannot get straight dos to find my .bin file. it says "PATH NOT FOUND" even though i know the path is correct. i was supposed to get new chips on tuesday but i am still waiting, the chip could be bad from me removing it.
thanks
jake
Old Jul 6, 2001 | 12:15 AM
cp87GTA's Avatar
Car: T/A / Grand Am
Engine: 383 SBC
Transmission: glide
Axle/Gears: 9" ford 5.67
thanks
jake
</font>
The address has to be exact! drive-:\directory\file.bin In dos. At least in mine, that's the only way it can find it.
Old Jul 6, 2001 | 12:42 PM
The address i type in is exact, however that still doesn't explain why it will now program
Old Jul 8, 2001 | 08:37 PM
Does any one else have any help to offer. the guy i need to talk to at intronics is on vacation. i tested for program voltage and i have that. please help. i want to get my car running.
thanks
jake
Old Jul 8, 2001 | 09:46 PM
cp87GTA's Avatar
Car: T/A / Grand Am
Engine: 383 SBC
Transmission: glide
thanks
jake
</font>
Try using the windows software. I have no trouble at all programming 27c128 chips in windows. My pp is only a couple of weeks old and it came with the windows sofware, much easier I think.
87 GTA 355/700r4
ported&polished 083 heads
xe268h comp cam
1 5/8 blackjack alumicote
homebuilt y pipe,pasesetter 3in mandrel cat back.
ported/manifold,upper plentum, tpis maf.
airfoil, 24# svo injectors, hypertech stage 3 chip, underdrive pulleys, erson roller rockers, chromemolley pushrods,2100 stall, shiftkit, 373 10 bolt.
Old Jul 8, 2001 | 09:54 PM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
I agree, if you CAN use the Windows Version, use it.
Old Jul 8, 2001 | 11:25 PM
Greenshamrock77's Avatar
If dos can not see the .bin file it might be system hidden.
82' Z-28. 327" w/ flat tops. 216/228/112LS. Pocket ported 041 heads 1.94/1.50 SS valves. World Class T-5 from a 91'. Best run? Runs with 2001 vette to 150mph! Soon to be converted over to TPI w/ supercharger.
Old Jul 9, 2001 | 09:48 AM
LeeH's Avatar
Car: 89 Firebird Formula
Engine: 389
Axle/Gears: Moser 4.11
Are you sure you aren't omitting the final backslash ("\") when it asks for the path to the bin files? Something like "\eprom\bins\"
eprom.exe will then show all the .bin files in the directory. I forget the slash from time to time, and eprom doesn't give any errors, just shows the directory name of "bin" as the only file in there...
I also have troubles using the windows version on my Athalon 850 PC, so I just use DOS in full screen mode.
Old Jul 9, 2001 | 09:34 PM
The windows version does not work either. Eprom.exe does not even recognize either of my hard drives (C:\ or D:\) and i put my bin in there to minimize typing errors. The guy at intronics comes back from vacation tomorow so maybe he can help me. thanks for the help so far.
Old Jul 11, 2001 | 04:27 PM
Does any one else have any ideas the intronics guy had none? Any thing else before i send it back and have a disabled car for a few more weeks?
Old Jul 11, 2001 | 07:25 PM
Car: Death Mobile
Engine: 666 c.i.
You are restarting your system in "MS-DOS MODE" aren't you. You can't just use Windows Explorer or the "RUN" command to execute FILEPROM or EPROM. You must use "SHUTDOWN" and then select "RESTART IN MS-DOS".
And when looking for files you MUST specify "C:\FILEDIRECTORYNAME\" with a closeing backslash AND keep the file directory under 8 characters - I doubt it supports long names. I put all my BINS in a directory called "BINS" so I just type "C:\BINS\" and it will list all my BINS.
Old Jul 12, 2001 | 09:07 AM
LeeH's Avatar
Engine: 389
Not to nitpick, but you should not need to restart your computer in M$DOS. It must be in full screen mode though (by hitting <Alt>+<Enter> in the dos window).
When it's in full screen mode, it gets most of the computer's resources as allocated by windows. I use it this way all the time - no problems.
Old Jul 12, 2001 | 04:12 PM
I finaly got it to work, it was the 2 chips i was using i got more and it works like a charm, however the arap.bin will not start my car.
thanks for all your help
jake
Old Jul 12, 2001 | 07:07 PM
Car: Death Mobile
Engine: 666 c.i.
Lee, if that works, great. Sometimes these DOS programs want to be DOS as per the method I mentioned due to communications with the parallel port. Some computers are forgiving...some are a pain in the butt.
Forcing it to restart in MS-DOS mode just eliminates one possible problem. Once you get it working (in ANY MODE), then you can experiment to see if you can stop a step.
86IROC112
Nov 7, 2015 06:50 AM
Bubbajones_ya
Oct 25, 2015 08:01 PM
ULTM8Z
Oct 2, 2015 01:25 PM
Luigytico09
Oct 1, 2015 08:46 AM
the_hamturdler
Sep 30, 2015 12:50 PM
