a couple questions
Old Jul 16, 2001 | 06:53 PM
Tricked-Out-Toy's Avatar
Car: 91 Z28
Engine: Lt1
Axle/Gears: 3.70 auburn pro 9"
a couple questions
First question, Im using the snapon scan tool and im reading a lean condition when the on open loop but then once it goes to closed loop it get RICH and never leans out at all, where useing tunercat in $8D can i lean out the closed loop fuel/air
Second question, once it goes into closed loop she runs good just real rich, exept if i try to go over 3800 4000 rpms she sputters and wont even run right i know this is a WOT calabration but where do i start? im dealing with the stock ECM on a 91 Z28 SD , and the tunercat progam.
also is there any websites that give examples of the mods and whet was done to the eprom, i found a couple but i was looking for more, thanks guys youve been a big help already- TOT
Old Jul 16, 2001 | 09:24 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
<font face="Verdana, Arial" size="2">Originally posted by Tricked-Out-Toy:
</font>
Closed loop is 14.7,
do you mean the BLs are correcting for a rich condition, or are having to be commanded rich?
If it's pig rich, I'd check the Fuel Pressure first.
If that's fine the slowly reduce the VE numbers in the rpm vs Map table.
Where have you been, for info?.
Frozer!!!
Jan 19, 2024 04:55 PM
chazman
Aug 28, 2018 03:25 PM
Cleotiz
Jan 6, 2018 08:56 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
