Need help with data table fron scantool
Old Jul 31, 2001 | 05:27 AM
max87Camaro's Avatar
My car: '87 Camaro 2,8L MPFI. I finished scantool lately and get datastream from it. I've converted it to the Excel table. Problem is, that my car stalls sometimes in traffic. Maybe can someone check my data table and give me some advice, what may be wrong with my engine or/and sensors. I can't find anything
Data:
http://my.tele2.ee/camaro/aldl.xls
At this stream, car stalls in the row 52.
[This message has been edited by max87Camaro (edited July 31, 2001).]
Old Jul 31, 2001 | 08:48 AM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
At a quick glance, your BLMs appear quite high (148s) indicating a lean condition and your IAC step counts are getting quite low.
My first suggestion would be to increase the mixture.
Old Jul 31, 2001 | 08:59 AM
How? Do you mean PROM editing? All my car is stock, including prom, so it must work. I've noticed too, that IAC is quite low, but what may cause this? I'm out of ideas...
Old Jul 31, 2001 | 08:45 PM
Lionsden's Avatar
Have you check fuel pressure? Weak pump or restricted fuel filter maybe.
Dan
[This message has been edited by Lionsden (edited July 31, 2001).]
Old Aug 1, 2001 | 03:29 AM
Fuel pressure is OK, 35psi@idle. So you think, that with that data is all OK? All sensors and ECM functions are OK?
I've checked other datastreams too and noticed, that every time I take my foot out of gas, BLM goes high (150-160). And if i stop the car, it causes sometimes (quite often) stalling the engine. What may cause rising BLM and why ECM does'nt try to compensate that? What can I do, to improve situation? Why IAC closes too much, because of high BLM?
[This message has been edited by max87Camaro (edited August 01, 2001).]
Falcon50
Aug 22, 2020 03:26 PM
antman89iroc
36
Jan 31, 2016 08:42 AM
bjpotter
Oct 4, 2015 07:48 PM
IROCThe5.7L
Sep 17, 2015 07:48 AM
ULTM8Z
Sep 16, 2015 09:15 AM
