corvette inj.'s
Old Jan 31, 2001 | 10:39 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
corvette inj.'s
I saw a post recently that said what year corvett had 24# inj. I thought it was 85 or 86 could some one verify what year it was
Old Feb 1, 2001 | 12:15 AM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
I am not sure. I believe the 90-91 SD version used 22#, based on what I've seen in the "hack".
Old Feb 1, 2001 | 12:27 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
94-96 LT1 Corvettes have 24lbs injectors, but I believe the TPI Corvettes are all 22lbs, and so are the 92-93 LT1's.
West Coast GM Shootout 2001!
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
Old Feb 1, 2001 | 06:03 AM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
88 350, I know exactly which post you are talking about, and it had me scratching my head.
Some guy posted, and said that in '85, the Vettes had 24# injectors. Then I stepped in and asked for proof, since I am running injectors from an '85 Corvette.
But untill somebody can prove it, I would say they are 22# because I am using them on my 305, and only run a little rich. I would think if I had 24#'s, I would get a code 45 or something.
If you live in Southeastern US, check us out!
South East Thirdgen
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey, 22# injectors,
JET AFPR, Ported Plenum,
TB Coolant Bypass, Custom Cold Air,
SSM SFC, KYB Shocks, Boxed LCAs, Wonder Bar,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
-->14.97 @ 94.9 MPH<--
'97 Bonneville SSE
Old Feb 1, 2001 | 08:38 PM
Wayquick4u's Avatar
The only year l98 vettes came with a 24# injectors was 85. All 85 vettes. goto www.corvetteforum.com and look it up on their message boards.
Old Feb 2, 2001 | 12:33 AM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
They vary some by who's doing the testing, and or reporting.
Some use a 3 bar presure standard and others 39-45 PSI, there is no standard.
I personally wouldn't fret about 2#/hr.
I tend to go big and leave some head room.
<cough> 55s on my 3.8L (sefi) <\cough>
Old Aug 4, 2001 | 11:59 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Diggin' this up from the archives.
The 85 Vettes ran a fuel pressure of only 35lbs, not 43 like in all other years. For this I'd imagine they would use a bigger injector to compensate.
GMTECH, I'm running 24lb/hr SVO injectors on my IROC (the svo injectors are about a 26lb/hr injector with GM fuel pressure) and although I run rich as hell, I don't throw any codes.
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
"I didn't know a bored out Ford could go so slow" -Shenandoah
PurelyPMD
May 5, 2016 04:57 PM
88SS6SPEED
Nov 11, 2015 07:05 AM
the_hamturdler
Sep 30, 2015 12:50 PM
dusterbd
Sep 29, 2015 08:40 AM
dbrochard
Wheels and Tires
Sep 25, 2015 05:40 PM
