PE delta AFR tables additive?
Old Sep 13, 2006 | 01:21 PM
AtomicTruck's Avatar
Car: Pro Stadium Tough Truck
Engine: Buick V6 272 cu in
Transmission: TH350
Axle/Gears: Broken most of the time
In 8D I see two tables for changing the PE AFR, AFR vs RPM and AFR vs Temp. Are the values of these two tables added together? If so then what is the scaling factor(s). For ANHT temp change is 22.66 percent in the normal operating temperatures AND the RPM change is 12.5 pecent at 3600 rpm.
So if you add these two percentages together you get 35% change to AFR. That would try to make the PE AFR 9.55. That seems WAY too low.
Old Sep 13, 2006 | 03:56 PM
MonteCarSlow's Avatar
Car: 1988 Monte Carlo SS
Engine: 5.7L TPI
Search the board for AFRTuner. A nice little app written by a board member that makes the job easy for editing those 2 tables. If the VE table is accurate, the AFR values you enter with this program will be accurate.
Old Sep 13, 2006 | 10:02 PM
Transmission: TH350
I'll find that app.
Thanks.
antman89iroc
36
Jan 31, 2016 08:42 AM
ULTM8Z
Oct 2, 2015 01:25 PM
skinny z
Carburetors
Sep 29, 2015 11:25 PM
355tpipickup
Sep 28, 2015 05:50 PM
ULTM8Z
Sep 16, 2015 09:15 AM
