bad ARAP?
Old Aug 11, 2001 | 08:57 PM
e-man's Avatar
Car: 89 formula
Engine: 383
bad ARAP?
Looking at the ARAP bin on winbin the PE vs RPM table looks weird 6400rpm-4000rpm is -7.82 and 3600,2400,2000rpm are blank is this normal for the ARAP?
Old Aug 13, 2001 | 01:51 AM
ZaphodB's Avatar
Car: Camaro IROC-Z '89
Engine: 350 TPI /w Procharger P1SC
Transmission: TH700R4 with Transgo shiftkit
Axle/Gears: 2.77 Borg Warner
<font face="Verdana, Arial" size="2">Originally posted by e-man:
Looking at the ARAP bin on winbin the PE vs RPM table looks weird 6400rpm-4000rpm is -7.82 and 3600,2400,2000rpm are blank is this normal for the ARAP?</font>
That is defintitively wrong. What is the values in the table if you look at it as raw data?
Mine reads 118 between 4000-6400 rpm in raw data.... And in % it reads approx 9.2%...
ZaphodB a.k.a Carl Andersson - zaphodb@faxancruisers.org
'89 Camaro IROC-Z 5.7L TPI - Mods under construction :-)
Custom ARAP Chip Under Development/180 t-stat, Edelbrock TES Headers,
SLP Airfoil, K&N Filters, Accel 8mm wires, Relocated MAT, AFPR @ 45 PSI
Old Aug 13, 2001 | 05:43 AM
e-man's Avatar
Car: 89 formula
Engine: 383
In hex its 118 for 6400-4000rpm and the blank rpms are 128 Im using the 6Ev007ecu
AmpleUnicorn88
Brakes
32
Nov 18, 2015 11:02 AM
3rdgenkindagal
Aftermarket Vendor Review
25
Oct 21, 2015 09:32 AM
L98GTA87
Oct 19, 2015 10:43 PM
dimented24x7
Sep 17, 2015 06:58 AM
gta892000
Sep 16, 2015 12:40 AM
