disabling VATS... No options in the 'flags' tab
Old Aug 17, 2001 | 12:57 PM
FullSendRacing's Avatar
Car: '85 Trans Am FAILBIRD
Axle/Gears: 4th gen torsen 3.42
When I start up Winbin, I can see/modify everything but the flags. There are no options at all in the pulldown menu, and there is no text next to the check boxes. Have I done something wrong? I'd really like to disable the VATS considering that at the moment it's being tricked by a circuit I built.
I have an '89 TPI, I'm using APYP_7165_89vette.ecu
Old Aug 17, 2001 | 01:40 PM
GregWestphal's Avatar
Car: '87 Camaro IROC-Z
Engine: 385 HSR
Axle/Gears: 3.42 posi
You're using an old/inferior version of the ecu file. Go to: http://www.area51.org.il/~zaphodb/gmecm/
and download the zip file 6Ev007.zip or the actual ecu file 6Ev007.ecu. You'll be amazed how much has been added and corrected.
Greg Westphal
'87 IROC 355TPI/A4
Old Aug 17, 2001 | 01:52 PM
Right on, thank you much
F-body-fan
Jan 12, 2023 01:49 PM
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
InfernalVortex
Apr 20, 2021 11:31 AM
gixxer92
May 18, 2017 11:20 AM
