wide band questions
wide band questions
I've got a LC-1 connected and I'm datalogging with the Logworks2 software but I can only log in time intervals. Before I bought it I didn't really know what I was going to log but i'd really like to log via RPM and the rpm converter is only for the LM-1? Anybody know a way to overcome this? Also has anyone ever connected an LC-1 directly to an 8746 in place of another sensor that's not used? i.e. A.I.R. or a/c?
Thanks.
Thanks.
I'm not familiar with the tbi bins-
Set the LC1 for 0-5V & 10-20 afr.
If your bin has a FP volts input, make sure your injector bias is set to use batt volts.
Hook LC1 to the FP volts pin and edit the aldl to log FP volts.
Edit xdf to display 10-20.
Some of the TBI guys may have a different or better way.
Terrell351
Jun 13, 2021 01:13 PM
9192camaro
16
Feb 3, 2019 12:21 AM
