What do you guys think about these numbers.
I need a little help in interperating these values.
http://home.rochester.rr.com/hoscar/8-23%20home.jpg
I am still unsure of where I should put the BPW.
I have an 88 formula, 700r4, and replaced the 305 block with a 350 block (~91-92 stock block) Intake, TBI, exhaust are original for car.
thanks
thanks
it's the 7747. and that was using the ASDU.bin file with the BPW at 170.
I am using techedge software to log the ALDL, but the screen shot was my own program that formats the log file.
88 Formula WS6 TBI 350
The other hobby
http://home.rochester.rr.com/hoscar/indexn.html
The other hobby
If I may make a suggestion, convert the MAP column to KPA instead of what it is now(?).
Then you can take the RPM X MAP and go to your fuel table and add or subtract the appropriate amount of fuel.
Just for curiousity sake would you email the Techedge data log to me? It is in text formatt correct?
wildkat@paonline.com
BlackphantomZ28
Aug 22, 2015 01:00 PM
