Converted to SD from MAF. Change TPS?
Old Sep 22, 2006 | 09:34 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
Ic thats the Maf is .54 but most non adjustable SD ones are around .65. Should I leave mine at .54 or move it up? Does it make a differance? Or should I just change everything in the chip?
Old Sep 22, 2006 | 09:44 PM
vernw's Avatar
Car: 91 Formula WS6 (Black, T-Tops)
Engine: 383 MiniRam (529 HP, 519 TQ - DD2K)
Transmission: Built '97 T56, Pro 5.0, CF-DF
Axle/Gears: 4.11 posi Ford 9"
You should be fine. The nice part about the speed density's (at least on the 7730) is they are "auto adjust", meaning the ECM takes the low reading from the TPS and uses that as it's "0%" value. As long as your TPS hits at least 4 volts at WOT, then everything will be fine.
jklein337
Sep 19, 2018 06:23 PM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
92camaroJoe
Aug 13, 2015 06:07 AM
