MAF software
Old Aug 25, 2001 | 08:29 PM
I Cant Think of Anything's Avatar
MAF software
I bought an ALDL computer link cable a few months ago that I use on my bro's 92 TPI SD. But I am unable to find software that works on my 89 Iroc 350 TPI. Can anyone tell me where to get diagnostic software for a MAF computer? Is there any free software out that that works?
1989 Iroc-Z Blue T-Tops
Modes:
Headers, B&M tranny, K&N's
Old Aug 25, 2001 | 10:41 PM
dgreene's Avatar
Car: 87 Formula 350
Transmission: 7004R
Maybe this will help....
http://members.tripod.com/moatesenheimer/gmecm/
dgreene
'87 Firebird Formula 350 TPI, Ported Plenum, Adj. Fuel reg, gutted cat, catback exhaust, air foil, K&N air filter, chip,170 thermostat,Borg Warner Posi 9 Bolt w/ 3.23 gears....soon to be making custom chips for this and my 87' GN
Old Aug 25, 2001 | 11:18 PM
I have tryed this software I am unable to make it link up with the car. Is there anything else i can use?
Modes:
Old Aug 25, 2001 | 11:27 PM
ZaphodB's Avatar
Car: Camaro IROC-Z '89
Engine: 350 TPI /w Procharger P1SC
Transmission: TH700R4 with Transgo shiftkit
Axle/Gears: 2.77 Borg Warner
<font face="Verdana, Arial" size="2">Originally posted by I Cant Think of Anything:
</font>
It works fine over here. What cable did you use? Remember that pin "B" has to be connected in the cable when you start the program otherwise it will not link up.... And the ignition has to be turned to "on" when you start linking up....
ZaphodB a.k.a Carl Andersson - zaphodb@faxancruisers.org
'89 Camaro IROC-Z 5.7L TPI - Mods under construction :-)
Custom ARAP Chip Under Development/180 t-stat, Edelbrock TES Headers,
SLP Airfoil, K&N Filters, Accel 8mm wires, Relocated MAT, AFPR @ 45 PSI
Old Aug 26, 2001 | 01:05 AM
I am using a cable made by AKM Electronics. They are listed in the prom burning tech article. When I run the software then click run to start link nothing happens. Is there any other free software out there?
Old Aug 26, 2001 | 01:21 AM
Craig Moates's Avatar
Car: 87 T/A
Engine: 441 SBC 12.5:1 0.680" Lift
Axle/Gears: 4.10 TruTrac Moser 9"
Take a healthier stab at getting it to work. Try all the obviously documented issues and get it to work, it will in all likelihood.
Old Aug 26, 2001 | 11:53 AM
james_fearn's Avatar
The cables for MAF and SD cars are different. The pin that has the info is different in the ALDL.
James
Old Aug 26, 2001 | 12:34 PM
Ohh, that would explain why it doesn’t work. Where can I get semantics on making a cable for a MAF? I have found some stuff from people who have made one for a SD but not MAF.
Old Aug 26, 2001 | 08:48 PM
Or can I just change the pins around on my cable made for a Speed Density?
Old Aug 26, 2001 | 10:00 PM
hectorsn's Avatar
Car: 78 Regal
Engine: 82 FBod LG4 305, 730 ECM
Transmission: M20
Axle/Gears: 4.10
Or can I just change the pins around on my cable made for a Speed Density?</font>
That should do it. I think you need to have the data line on E and the cable now has it at M.
Old Aug 27, 2001 | 12:48 AM
ZaphodB's Avatar
On a car with 1227165 ECU and MAF, the only pins you need to get Carigs software working is A, B and M....
B and A are the rightmost pins in the upper row of the ALDL connector, and M is the rightmost one in the lower row, right beneath A.....
Something like:
BA
.M
[This message has been edited by ZaphodB (edited August 26, 2001).]
Old Aug 27, 2001 | 02:32 PM
94ZRagtop's Avatar
Howdy!
If you bought one of my cables that was orginally for a TPI MAP car, then odds are good that it does not have a 10k resistor in there for the ALDL link with a TPI MAF car. Normally, I don't include the resistor because it's not needed on 95% of the cables I sell.
Open up the gray hood where the OBDI style connector hooks up. If there is a 10k resistor, it will be between pins 1 and 3, with wires going to the ALDL connector.
If there is no 10k resistor, I'd be happy to put one in there, and I'll pick up shipping (US Mail) both ways. No problem, just a little time inconvenience.
If there is a 10k resistor, then I must ask, what kind of computer (laptop) you're trying to use with Craig's software? I've had some trouble with some of the faster machines and the TPI MAF ECM (I've got one here on the bench - that I'm going to send to TTS to see if we can get a version of Datamaster ).
I'm headed out of town in 30 minutes, so I'll be offline for a while, but email me at andrew@akmcables.com with any questions.
Thanks,
Andrew
(PS - thanks to the guy who pointed this out to me you know who you are! I owe ya one)
Old Aug 27, 2001 | 03:27 PM
Warlock's Avatar
FYI, while I have a vette, its still TPI and MAF. The data is E not M on my car. (No wires connected to M at all on the connector)
Old Aug 27, 2001 | 05:15 PM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
Engine: 350, ZZ4 equivalent
Transmission: Pro-Built Road Race 700R4
Axle/Gears: 3.23 Dana 44
I changed my name from "I can’t think of anything" to "89 Iroc Z"
Okay I took some pics of my cable etc…
Here is a picture of where my cable plugs into the ALDL:
There is no resistor under the gray hood:
A picture of the front of the circuit board:
I did find a 10k resistor on the back of the circuit board (as shown below) is this what I need?
If anything is not right here for a MAF car please tell me. I did try for another 30 min today to get this to work on my MAF with no luck. It works great on my brothers 92 TPI speed density. That’s why I think it's the software. Any ideas would be greatly appreciated.
Old Sep 9, 2001 | 01:19 AM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
I was told by 94ZRagtop (Andrew) that the cable is okay.
My laptop is a Pentium 120 with 64 megs of ram running Windows 95 B. I know the com port and all the setting are right b/c this computer works with my 92 Camaro. The only difference is the software I use. Anyone having the same problem?
[This message has been edited by 89 Iroc Z (edited September 08, 2001).]
Mark_ZZ3
May 24, 2018 01:02 PM
BumpaD82
Feb 26, 2016 02:57 PM
racereese
Oct 3, 2015 03:46 PM
Ikes 91Z
LSX and LTX Parts
Sep 13, 2015 09:03 AM
