how much?
Old Sep 11, 2001 | 12:50 AM
formula5's Avatar
how much?
Is a 1982 Z28 prom for the pace car worth anything?I'm not trying to sell it.But if it's not worth saving then would'nt that prom work for my 85 ecm as a blank?
Old Sep 11, 2001 | 05:50 AM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
Its only worth what the chip itself is worth. However, some of the older chips are not erasable, therefore, you might not be able to change it. If it has the "window" then you can use it. If not, then its stuck as an '82 "pace car" chip as you call it.
FREE CARFAX Record Check
If you live in Southeastern US, check us out!
South East Thirdgen
GM Master Tech
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey,
22# injectors,
Whatever chip I feel like burning,
JET AFPR, Ported Plenum,
TB Coolant Bypass, Custom Cold Air,
SSM SFC, KYB Shocks, Boxed LCAs, Wonder Bar,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
3.73 Posi
4wheel Disc Brakes
Summit 1-5/8" headers, 2.5" Dynomax catback.
Best 1/8: 9.519@72.74
'97 Bonneville SSE
