GM list 4 chips for the 86 5 speed cars, all for the same ecm please help.
Car: 86 Z28
Transmission: W/C T-5
Axle/Gears: 9 BOLT 3.45 POSI
I swapped out the auto for a 5 speed and I would like to switch to a 5 speed chip but the gm list 2 chips for the m39 5 speed and 2 for the mc4 5 speed, what are the diffrences? they are all for the same model computer, the tranny from my car is from a 88 iroc, I guess the auto chip is looking for a vss whitch the 5 speed car does not have in the tranny. alll of these chips are for the 86 z with the h code (LG4) What is the diffrence? will any of these chips work? is one better then the other? thanks
86Z28, GM 350, Jet perf Q-jet & chip Dual snorkel air cleaner, Edelbrock performer intake, Edelbrock headers, Edelbrock cat-back, Off road pipe, MSD 6AL, Accel Super Coil, Taylor Spiro-pro wires, Rapid fire plugs, Jet fan switch, World class t-5, Hurst Short Throw Shifter, Ram Flywheel, Center force dual friction clutch,Aluminum drive shaft, BW disc rear 3.45's & a posi, PBR calipers, Earls braided brake lines, Polygrapite bushings all the way around, poly tranny mount & torque arm mount, Hotchkis lower control arms & panhard rod, Rancho limiter straps, KYB struts & shocks, Gm Wonderbar, Edelbrock strut tower brace, SSM sub frame connectors, Jamex lowering springs, Carbon metallic brake pads, Crossed drilled rotors, Mobil 1 Tranny fluid & motor oil, GM syntheic rear end oil, K&N, Grant stering wheel, 1,200 watt system, Jet Black Paint, 91 Z28 rims, 92 wing, Tinted windows.
Car: An Ol Buick
Engine: Vsick
<font face="Verdana, Arial" size="2">Originally posted by BLACK Z:
</font>
</font>
The Bins at DIY are EFI related,
My best luck with the CCC has always been to use the chip ecm carb cals from the ZZZ kit. But, I think that is auto only.
Reading Doug Roe's Q Jet book would be an excellent start.
late 86 was when world class t5's were phased in. Different gear ratio's came in the different tranies. I would bet this is the difference in the chips. As far as timing changes.
87z 383,afr 190's, comp hyd roller(242/248-.540/.562,114 sep),Ported and polished mini ram, 30lb inj, 3.42 gears, tremec 5spd, , 1,3/4" slp headers, speed pro bank to bank-wb02.
"Just remember children, no man can beat you once youv'e found the cliterous." 'chef'
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Late 86? My data shows GM didnt use the WCT5 until 1988 models, which would be late 1987 calendar year.
West Coast GM Shootout 2001!
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
1991 Camaro Z28
13.25 @ 107.18 MPH
Southern California
Car: 86 Z28
btt
Car: 86 Z28
it turns out the chips is for a m39, and it is a anw, so do you guys have any more info for me? thanks
1992 Trans Am
May 10, 2023 07:19 PM
NBrehm
Aug 25, 2015 11:49 PM
Linson
Aug 21, 2015 02:12 PM
