just popped in the ARAP
Old Sep 21, 2001 | 02:31 PM
v8power's Avatar
I just threw in the ARAP to my 86 MAF TPI
the 9th is disconnected
on start up it take a few seconds or even a couple tries to start it
it definently woke my car up at WOT still have to do a scan and see where it sits
but has any one experienced the hard start and rough idle?
oh I gues I should add I modified the bin to lower fan temps a bit and changed it for a manual tranny no VATS and lowered the rpm limit and turned all TCC stuff to zero
other than that I havent done any thing to it
1986 IROC 350 5spd
just installed a TPI from a 1988 IROC, 24# lt1 injectors,165 ECM MAF, custom sub frame
[This message has been edited by v8power (edited September 21, 2001).]
Old Sep 21, 2001 | 02:51 PM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
Play with the Spark Advance. It may be a bit high at idle. Do have your scan tool running while cranking.
Old Sep 21, 2001 | 03:35 PM
v8power's Avatar
not yet I took it out for a burn at lunch I will hook up a scanner when I get home
i dont have a programmer yet at home so I play at work burn a chip before lunch take it for a rip then usually one for going home
it a PITA but I will be making a programmer or buying one really soon
1986 IROC 350 5spd
Old Sep 21, 2001 | 04:48 PM
Craig Moates's Avatar
Car: 87 T/A
Engine: 441 SBC 12.5:1 0.680" Lift
Axle/Gears: 4.10 TruTrac Moser 9"
You need to get the FI sizing dialed in to get a nice easy start on ARAP. Also make sure your cold-start injector is disconnected.
Old Sep 21, 2001 | 06:08 PM
Car: Death Mobile
Engine: 666 c.i.
<font face="Verdana, Arial" size="2">Originally posted by Craig Moates:
You need to get the FI sizing dialed in to get a nice easy start on ARAP. Also make sure your cold-start injector is disconnected.</font>
Good point Craig. I have found that it is best to play with the Injector Constant a bit and not just use its "rated" value.
RS Reaper
Oct 17, 2018 07:52 PM
Luigytico09
Oct 1, 2015 08:46 AM
aaron7
Sep 30, 2015 09:15 AM
RS Reaper
Sep 27, 2015 07:04 PM
Lmancha96
Sep 25, 2015 08:11 PM
