Correct way to remove prom from memcal?
Old Oct 5, 2006 | 07:46 PM
RSFreak's Avatar
Car: 1985 Camaro, 1986 Trans Am
Engine: 5.0L carbed and 5.0L TPI
Transmission: TH700R4
Axle/Gears: 3.23 and 3.27 posi
I just picked up a '730 ecm and MAP sensor from an LH0 and am about to do the '302 to '730 swap. But first I need to install my eprom with the correct bin. How do I de-solder the prom from the carrier without destroying it and everything around it?
Old Oct 5, 2006 | 09:39 PM
ryan.h's Avatar
I've got an adapter in the mall that will solve your problems... Then you won't have to desolder anything... Just solder the board, and plug it in. Cheap too.
Old Oct 6, 2006 | 08:20 AM
MonteCarSlow's Avatar
Car: 1988 Monte Carlo SS
Engine: 5.7L TPI
Using a small side cutter, cut the pins of the eprom near where they come out of the chip. Next, it would be worth while to install a ZIF socket (or just a plain socket if you don't plan on much tuning). Just place the socket over top of the pins that remain from the eprom, and then solder the legs of the socket to the chip legs that remain.
If you have a socket with long enough leads, you can remove the pins from the old eprom by putting the memcal in a vise and using pliers to remove the pins while you touch them with the tip of your soldering iron. Then solder in the socket...
Old Oct 6, 2006 | 06:44 PM
RSFreak's Avatar
Thanks MonteCarSlow. Yeah, I want to install a ZIF, but it looks like it might interfere with the limp-home module, or calpak I think its called.
Old Oct 7, 2006 | 11:55 AM
80Sierra's Avatar
Car: 80 GMC K35
Engine: TPI 355
Transmission: NV4500
Axle/Gears: 4.10
If you buy a low profile zif from "GotSpeedRacing" on ebay, and slightly shave the one end, you can get a ZIF onto the memcal. I've got one in my 7730 anyways
If you want pics, lemme know, and I'll snap some for you at the next chance I get.
Old Oct 7, 2006 | 12:46 PM
1987earthquake's Avatar
Car: 1987 Camaro Z28
Engine: 5.3L
Axle/Gears: 3.42LSD
Take pics. I would like to see them
Old Oct 7, 2006 | 06:04 PM
RSFreak's Avatar
Yeah 80Sierra, pics would be great! Thanks.
Glowsock
Jul 24, 2025 03:15 PM
Keith5
Aug 27, 2015 04:37 PM
Sanjay
Aug 12, 2015 03:41 PM
djmarch
Aug 11, 2015 10:22 AM
3rdgenparts
Aug 8, 2015 07:09 PM
