BLM values
Old Oct 10, 2001 | 08:04 AM
88gta305's Avatar
Car: 77 Corvette
Engine: ZZ3/nitrous
Transmission: THM 400
BLM values
OK, This may not be qa prom problem, but my BLM values are:
Cell 0 BLM 150
1 144
2 138
3 150
v v
15 151
These values change slightly, the INT is sitting around 128 (varies as expected), I still have 19# injectors in the 350 motor, is this a lean out caused by small injectors, or is it a prom problem.
The prom is correct for an 88 350. BTW, the BPW for the injectors sits pretty close to 5 under fairly spirited accelaration TPS ~ 75%.
Cheers
Richard.
88 GTA, 350 L98, used to be 305, 88 350 PROM,
19# injectors, Ported Plenum, throotle body bypass, A.I.R delete, Dynomax 3" catback, Hi Flo Cat.
Old Oct 10, 2001 | 08:09 AM
hotpowerandperf's Avatar
The 350 PROM you are using is calibrated for 23 lb injectors. Since you are using 19 lb injectors the computer will "add fuel" because it is not injecting as much as it thinks it is. Change the injector constant to 23 lb and you numbers will be closer. You can tune from there.
John
Heart of Texas Power and Performance
Old Oct 10, 2001 | 08:56 AM
88gta305's Avatar
Car: 77 Corvette
Engine: ZZ3/nitrous
Thanks John, I will give it a go/.
Cheers
Richard
Old Oct 10, 2001 | 10:15 AM
leirch's Avatar
I thought you'd want to set the constant to 19lb since that is the size of injector your using. Setting it higher would lean the car out more than it already is. That would be bad..
Brendan
1987 IROC-Z L98,SR,EB 6085's,LPE 219/219 Cam, Crane 1.6RR, EB TPI Base, 58mm TB, Stock T5, 30lb SVO, AFPR, K&N, EB TES, Catco Cat, 3" Borla Cat-Back, Accel cap,rotor,distro/other crap, Aluminum DS, 94 Disk Rear, Adjustable Prop Valve, Precision 3.73 Gears, Weld in Sub-Frame Connectors, Hotchkis LCA's, KYB Shocks/Struts, Poly Bushings all over the place, Moog Upper/Lower Ball joints and Tie Rods ends/Idler Arm, Big stereo, 730SD Conversion.
To see the ROC, Check out the webpage Here
Old Oct 10, 2001 | 10:42 AM
You are correct the constant is currently 23 and should be 19. Sorry about the mix up.
John
Old Oct 10, 2001 | 10:59 AM
88gta305's Avatar
Car: 77 Corvette
Engine: ZZ3/nitrous
Ok, Thanks guys, I will give it a try.
Cheers
Richard
Mark_ZZ3
May 24, 2018 01:02 PM
antman89iroc
36
Jan 31, 2016 08:42 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
ULTM8Z
Sep 16, 2015 09:15 AM
