BLM Datamaster
Old Oct 10, 2001 | 03:02 PM
ptc92rs's Avatar
BLM Datamaster
Does anyone use Datamaster? I'm not sure wich parameter = BLM. It seems my choices are: LTerm Adj, STerm-C Counts, LTerm-C Counts, and STerm-P. Any ideas??????
Old Oct 10, 2001 | 03:15 PM
davidjon_99's Avatar
<font face="Verdana, Arial" size="2">Originally posted by ptc92rs:
Does anyone use Datamaster? I'm not sure wich parameter = BLM. It seems my choices are: LTerm Adj, STerm-C Counts, LTerm-C Counts, and STerm-P. Any ideas??????</font>
It seems that DataMaster uses different terminology for different versions of thier software. I use the DM32x85 for my truck and it doesn't have any of those. It does have Long term (which is BLM) and Short term.
Is your LTerm Adj and STerm-P shown as percentages or as smaller single or double digit positive and negative numbers? If so, those might be the percentages over and under 128. For example a 10 would mean something like you're 10% above 128.
Are the LTerm-C Counts and STerm-C Counts shown ase three digit numbers close to 128? If so, your LTerm-C number would probably be your BLM.
If neither of the above is true, I don't have any idea. :-) I've tried emailing TTS with some of my questions, but they have never responded.
Old Oct 10, 2001 | 03:32 PM
ptc92rs's Avatar
My initial thinking is that LTerm-C = BLM. Not only does it remain more steady but it most closely resembles BLM from my MAC scan tool. STerm-P IS a + or - number, maybe the percentage. But the LTerm Adj and STerm-C numbers jump back and forth a good bit between @ 110 and 148.
Old Oct 10, 2001 | 04:36 PM
My initial thinking is that LTerm-C = BLM. Not only does it remain more steady but it most closely resembles BLM from my MAC scan tool. STerm-P IS a + or - number, maybe the percentage. But the LTerm Adj and STerm-C numbers jump back and forth a good bit between @ 110 and 148.</font>
Sounds like you're on the right track.
Mark_ZZ3
May 24, 2018 01:02 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
antman89iroc
36
Jan 31, 2016 08:42 AM
ULTM8Z
Sep 16, 2015 09:15 AM
CORV3TT3
Aug 23, 2015 11:26 AM
