Flash prom question...Easy one!
Engine: 2 mice and a cat
Could someone please give me the exact details for the flash prom in a 89 vette. I have the UV ones but am tired of having to use the light and would like to get some flash. I have searched around and see that everyone is using the AT29C256. The problem is when I went to DigiKey there are 2 pages worth of these and I am no electric genious. Mechanical perhaps, but not electrical
IF someone could post the exact specs. i.e., AT29C256-12JC-ND I would greatly appreciate it. Thanks
http://www.corvetteforum.net/c4/ski_dwn_it/
<b>67 Chevelle</b>
509 Merlin Crate Engine
585 Hp 637 Ft/Lbs
<b>1989 White coupe</b>
Open air box, Modified mass air, TB bypass,160 Stat, manual fan switch and lower temp switch, MAT sensor relocated, Air foil, gutted cats, flowmaster mufflers.
Soon to have Roller rockers.
When I die, I want to die quietly in my sleep like my grandfather did,
not screaming in terror like his passengers
IF someone could post the exact specs. i.e., AT29C256-12JC-ND I would greatly appreciate it. Thanks------------------
http://www.corvetteforum.net/c4/ski_dwn_it/ <b>67 Chevelle</b>
585 Hp 637 Ft/Lbs
anyone else with specifics or advise?
<b>67 Chevelle</b>
585 Hp 637 Ft/Lbs
585 Hp 637 Ft/Lbs
<font face="Verdana, Arial" size="2">Originally posted by ski_dwn_it:
</font>
</font>
and found 29C256-12PC ($4.39 ea.) and AT29C256-90PC ($5.55 ea.). Both are 28 pin flash proms that should work. The first one is 120ns, which will work. The second one is 90ns, which is probably faster than you need, but it won't hurt anything. They seem to be pretty reasonably priced.
The only thing I'm not sure about is that these are 5 volt proms. I'm not sure if the application requires higher voltage proms, say 12.5 volts. Anyone else want to jump in and help?
[This message has been edited by davidjon_99 (edited October 11, 2001).]
Car: Death Mobile
Engine: 666 c.i.
The AT29C256s work fine on a MAF car IF the Programmer is working properly. The ECM reads the AT29C256 just fine. You will have to load the 16K BIN properly onto the upper half of the 32K AT29C256. There are a number of methods to do that.
<font face="Verdana, Arial" size="2">Originally posted by Glenn91L98GTA:
The AT29C256s work fine on a MAF car IF the Programmer is working properly. The ECM reads the AT29C256 just fine. You will have to load the 16K BIN properly onto the upper half of the 32K AT29C256. There are a number of methods to do that.</font>
I have a Digi-Key low-profile ZIF socket on a V8 MemCal; works fine. ECU EPROM cover even fits.
I "double/stack" the 16kb BINs to load the 256 chips. Hey, whatever works...
