Tunercat and Definition files
Old Oct 11, 2001 | 04:51 PM
ryn28's Avatar
Car: 1986 Camaro Z-28
Engine: Chevy ZZ4
Transmission: Select Built 700R4
Axle/Gears: Moser Axles / 3.73 Richmond Gears
I just got all the stuff I need to burn proms and I'm waiting for the $32 definition file I need to use with my 86 camaro. I was planning on using most of the ARAP bin as a starting point as my car now as the ZZ-4 in it. I posted about this before so I know what I want to do for the most part but I now see that the ARAP bin needs to be read with the $6E definition file. Just to double check, this means I have to get that file also just so I can see what's in it, and then copy the parameters I want into my file?
I think that's it right? Just when I thought I had everything I needed too, go figure.
Old Oct 11, 2001 | 08:13 PM
TC602's Avatar
Car: 86 IROC
Engine: ZZ4
Transmission: T5 WC
You might as well use the $6E code. I also have an 86 Iroc, and I use the $6E code. All you have to do mechanicaly is disconnect the 9th injector. Then program your PROM with the ARAP bin.
Old Oct 12, 2001 | 01:27 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
The $32 will let you read and edit the prom you have now, but you'll need the $6E as well to be able to read and edit the ARAP bin.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
317 RWHP, 418 RWTQ
13.23 @ 107.62 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Member: SoCal F-Bodies
-=ICON Motorsports=-
Old Oct 12, 2001 | 10:42 AM
Momar's Avatar
So is there any real differences between $6E and $32 other than the cold start injector. Does it cause any problems on the older tuned ports(87 in specific) if you get rid of the csi. Just trying to figure this all out so that I will know as much as possible when I get my engine built and start programming my own chips. Thanks for all of the help
InfernalVortex
Apr 20, 2021 11:31 AM
Rocket-Doc
Nov 14, 2015 02:08 PM
ULTM8Z
Oct 2, 2015 01:25 PM
Jonas Earl
Sep 27, 2015 07:39 AM
MitcherNeaf
Sep 24, 2015 09:23 PM
