Wideband O2...
Old Oct 14, 2001 | 05:10 PM
Nomar116's Avatar
Wideband O2...
Im curious what one is... I know they're $$$ but the local dyno shop has one and once I get the car close to being dialed in, I figured I could go record some better data and then burn a chip Thoughts?
Paul
90 Red Convertible
100k running great
ZAINO!!!
383 Stroked.... LT4 Hot Cam... Forged Elgen Pistons Scat 9000 Crank Elgen 5.7" rods New Lifters w/ 1.6 Rockers and hardened Pushrods Super Ram Intake Hooker Headers and Y pipe into Gutted Cat with Monza Mufflers (WAY TO LOUD!!) Adj Regulator K&N Shift Kit High stall converter 160 termo, ZR1 Rims.... Red Calipers....Alpine head unit, Kenwood 6x9 4 ways, Polk DX 6 1/2 compnents, MTX 240 amp, Viper 550 alarm,
www.corvetteforum.net/c4/nomar116/
Old Oct 14, 2001 | 06:07 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
<font face="Verdana, Arial" size="2">Originally posted by Nomar116:
Paul
</font>
The stock one in your car is a switching type, all it's meant to do is switch from rich to lean at 14.7:1
A true wide band will read AFRs from 20:1 to about 10.6:1.
There was is a DIY version that while not lab grade used a $3 Printed Circuit board, $12 worth of parts, and $130 sensor. Uses a DVM for reading the output. Not fancy but functional.
A WB is a tuning aid just as an EGT or G-Tech is. Using the right combination of tools is the name of the game.
You still have to figure out what AFR your engine runs best at, there is no MAGIC AFR, it's still about testing, dyno will get you close, but you still have to final tune it.
Old Oct 15, 2001 | 03:36 PM
a73camaro's Avatar
It has all the info.
http://diy-efi.org/diy_efi/projects/diy_wb/
Azrael91966669
25
Jun 20, 2017 04:04 AM
efiguy
Sep 27, 2015 01:30 PM
tuningnewb
Sep 23, 2015 07:06 PM
IROCThe5.7L
Aug 10, 2015 11:24 AM
TRAXION
62
Jul 31, 2007 08:28 PM
