AKM vs. Diacom...
Old Oct 13, 2001 | 03:59 PM
Nomar116's Avatar
AKM vs. Diacom...
I have to make a decision. Is it worth the extra investment on my car for the Diacom as per easy user interface or should I save the money and buy the AKM? If so is the webpage offering the cable for $90 AKM that is a good place to get an OBD1 connection? I dont want to go splicing anything in too lazy but I really want a good price...
Paul
90 Red Convertible
100k running great
ZAINO!!!
383 Stroked.... LT4 Hot Cam... Forged Elgen Pistons Scat 9000 Crank Elgen 5.7" rods New Lifters w/ 1.6 Rockers and hardened Pushrods Super Ram Intake Hooker Headers and Y pipe into Gutted Cat with Monza Mufflers (WAY TO LOUD!!) Adj Regulator K&N Shift Kit High stall converter 160 termo, ZR1 Rims.... Red Calipers....Alpine head unit, Kenwood 6x9 4 ways, Polk DX 6 1/2 compnents, MTX 240 amp, Viper 550 alarm,
www.corvetteforum.net/c4/nomar116/
Old Oct 15, 2001 | 04:36 AM
SappySE107's Avatar
If you have software that will work for your car (I use freescan, I don't know if it will work for you or not), then I would get the AKM cable. If you can find someone to make you one, go for it. My friend can make them but I don't know how into it he is for selling them. I know he sold a few for 50 bucks, and made the ALDL connector out of one of those plastic code scanners you get at autozone (expensive paperclip).
I think diacom has its own special cable for running a parallel port, vs the serial port that the AKM cable uses. This is why I asked about the software you are going to be using.
Old Oct 15, 2001 | 09:01 AM
leirch's Avatar
I have Diacom, it works pretty well. I was able to get my copy used with all of the orignal packaging and literature. The guy even threw in a 386/16mhz laptop to run it with also!
All for 200bucks. If you can find a good deal like I did then Diacom would be worth it. But, there is no way I would pay full price for Diacom, Craigs software works just as well, and its free.
Brendan
1987 IROC-Z L98,SR,EB 6085's,LPE 219/219 Cam, Crane 1.6RR, EB TPI Base, 58mm TB, Stock T5, 30lb SVO, AFPR, K&N, EB TES, Catco Cat, 3" Borla Cat-Back, Accel cap,rotor,distro/other crap, Aluminum DS, 94 Disk Rear, Adjustable Prop Valve, Precision 3.73 Gears, Weld in Sub-Frame Connectors, Hotchkis LCA's, KYB Shocks/Struts, Poly Bushings all over the place, Moog Upper/Lower Ball joints and Tie Rods ends/Idler Arm, Big stereo, 730SD Conversion.
To see the ROC, Check out the webpage Here
Old Oct 15, 2001 | 10:22 PM
Bobalos's Avatar
Personally I like the DataMaster software & the AKM cable. I think that it is a nice package for the price, but if you are a mechanic & you have to diagnose several models & types, Diacom makes more sense.
BW
Old Oct 16, 2001 | 07:35 AM
Momar's Avatar
What all does datamaster work with exactly. I will be runing a 87 tuned port setup. Will it work.
Thanks for your help
Old Oct 16, 2001 | 03:06 PM
Bobalos's Avatar
http://www.ttspowersystems.com/index.html
It does not look like it. Looks like the oldest that they go back is 90. I think that your car is a MAF car is it not? if you change to a SD setup, you could use it, but that is a long way around getting thier software.
BW
3.8TransAM
Sep 17, 2015 02:16 PM
flinx
Jul 17, 2001 07:43 PM
Steve10
Jul 17, 2001 07:55 AM
poorboy8
Jul 13, 2001 08:18 AM
Steve10
Jun 27, 2001 07:25 AM
