4 wire heated O2...
Old Oct 26, 2001 | 06:31 PM
David 91RS/Z28's Avatar
4 wire heated O2...
How are you guys installing these on a single wire setup? I need to convert since my long tubes are causing the computer to go in and out of closed loop. I understand there is a power and ground but what about the 2 other wires? Looking at a schematic(late model LS1 f-body) each of those wires look to be signal(high & low) if I'm correct. Any help is appreciated!
David Tuschhoff
1991 RS/Z28 Camaro
FI 355ci NA SBC V8 M5.
12.47 @ 110.7mph 1.80 60'
Best mph of 111.6.
My f-body page!
Old Oct 26, 2001 | 07:13 PM
Brent's Avatar
Two wires power the heater. One goes to the ECM and the last is the sensor ground (3 and 1 wire sensors ground through the sensor body).
Old Oct 26, 2001 | 11:19 PM
Looking at the schematic, it says there is a ground, power, high signal and low signal where both of the latter two feed the computer. How do you get 2 wires that power the sensor out of this?
David Tuschhoff
1991 RS/Z28 Camaro
Best mph of 111.6.
My f-body page!
Old Oct 26, 2001 | 11:23 PM
crucial's Avatar
You probably got the wrong sensor. Did you get a vette ZR1 sensor ?? That one should have 3 wires. Two white wires for power and ground for the heating element inside it and one black wire for the signal to the ECM. I'd return what you have and get one of those... That doesnt sound like a sensor you could use with the ECMs in our cars.
1991 Z28 5.7 TPI
ZZ4 heads, ZZ4 cam, Harland Sharp roller rockers, Accel base, SLP siamesed runners, 52MM SLP Throttle Body, Hooker Headers, Flowmaster catback, MSD6A ignition, Home made ramair system, 2500 stall, bullet proof 700R4, aluminum driveshaft...
Soon to be installed. WC T5 !
Old Oct 27, 2001 | 12:32 AM
Brent's Avatar
1. +12v for the heater
2. Grd for the heater
3. Sensor ouput to ecm
4. Grd for sensor to ecm
I never said 2 wires power the sensor. I said there are two wires for the heater.
Perhaps my description was poor. My appologies.
Old Oct 27, 2001 | 01:23 AM
V8Astro Captain's Avatar
Car: Bee-Bowdy
Engine: blowd tree-fity
Transmission: sebin hunnerd
Axle/Gears: fo-tins
You can get a 3-wire O2 for a '92 Astro VIN "Z" code. It's the same heated sensor without the redundant ground.
Old Oct 27, 2001 | 10:29 AM
Thanks guys! I haven't bought the sensor yet, we had some here at our shop and I'm thinking I may try to use one.
Brent, so I can run the 2 grounds together then?
V8 astro, from what I've been reading the 4 wires work better.
David Tuschhoff
1991 RS/Z28 Camaro
Best mph of 111.6.
My f-body page!
Old Oct 27, 2001 | 12:00 PM
Brent's Avatar
I would ground them directly to the engine. This is where the single wire O2 grounds to through the exhaust manifold and cyl head.
[This message has been edited by Brent (edited October 27, 2001).]
Old Oct 27, 2001 | 07:01 PM
Car: Bee-Bowdy
Axle/Gears: fo-tins
<font face="Verdana, Arial" size="2">Originally posted by David 91RS/Z28:
</font>
Yeah, probably does. I figured I say just in case the 4-wire ends up costing a bunch. I know the 3-wire kind isn't that much. I think I may try that on mine. My Y-pipe is where the factory O2 sensor was but I moved it when I did the swap. Hmmm...
Old Oct 28, 2001 | 08:01 PM
JPrevost's Avatar
Car: 91 Red Sled
http://www.goautocenter.com/super_deals.htm
$20 for a 4 wire
Old Oct 29, 2001 | 01:03 AM
Matt87GTA's Avatar
Car: 1987 Trans Am GTA
Engine: Miniram'd 383, 24X LS1 PCM
Transmission: TH700R4, 4200 stall
Axle/Gears: 9", 4.33:1
FYI, The 'redundent' ground is there because the PCM that these sensor's usually work with will run diagnostics on the heater circuit itself to see if the sensor's heater is working to specs.....
The three wire one is a 'dumb' heated O2 and doesn't have daignostics run on it by the PCM. If the heater element fails, the PCM never knows. Either one can be made to work on our cars......
1987 GTA L98 MD8
355, TFS Heads, LT4 Hot Cam
My GTA
The Minnesota F-body Club
Old Oct 29, 2001 | 04:16 AM
JoBy's Avatar
Car: 1984 Corvette
Engine: Turbo 350
Transmission: 4L80E with TCI T-Com
If you have a 1-wire now then get a 3-wire. The extra sensor ground on the 4-wire is supposed to go to the ECM together with the sensor signal to minimize signal error. If you don't have that ground now, then you don't need a sensor that has it.
3-wire is a heated 1-wire.
4-wire is a heated 2-wire.
The two heater wires are usually the same color. connect on to ground and one to 12V. Polarity does not matter for the heater wires.
Jonas Bylund
Old Oct 29, 2001 | 07:07 PM
gsf-87IROC's Avatar
Car: 87 IROC-Z
Engine: 383 HSR $8D
I have used this sensor succesfully for a while now...I used the extra wire as a redundant ground.
The only problem I have run into is that it still takes forever to go into closed loop due to the closed loop delay in the '165 code. I am going to adjust this eventually.
GregF
87 IROC
Old Oct 29, 2001 | 07:59 PM
Matt87GTA's Avatar
<font face="Verdana, Arial" size="2">Originally posted by JoBy:
The extra sensor ground on the 4-wire is supposed to go to the ECM together with the sensor signal to minimize signal error.</font>
AHHHH... That's right!! Sorry bout that folks. I was mistaken about the heater diag stuff... JoBy is right about this. The extra ground is to ground the sensor's signal output to the same ground as the PCM to keep that issue from being an unintended variable... The heater diag stuff operates using the heater element being grounded through the other ground wire that a 3-wire sensor would also have....
1987 GTA L98 MD8
My GTA
ndndndnd
Carburetors
17
Sep 5, 2015 06:24 PM
mustangman65_79
Sep 1, 2015 03:51 PM
86IROC112
Aug 21, 2015 07:20 PM
stalkier
Aug 21, 2015 01:54 AM
kyle5647
Aug 15, 2015 11:56 PM
