Tuner Cat Up and Running... Some questions...
Old Nov 8, 2001 | 08:56 PM
Nomar116's Avatar
I noticed a few things... One it seems as though several settings (like rev limiter and "highway mode") are set to the mph of 255... Why so unreasonable and is this incorrect? This is from the stock chip btw. I also noticed that the number of cylinders is set at 0..... With step incriments of 32 going past 100 (I could easily type in 8 however) One last thing, Glenn you told me to set my cylinder volume at 784, my calculations say 780.. which is correct for a 383... Currently the volume is at 713 cc/cyl...
Anyway anything worth checkin out initially. Im just trying to save chips. I have started under the ecm constants, and will also need to find some eproms, the ones i have arnt erasable...
Paul
90 Red Convertible
100k running great
ZAINO!!!
383 Stroked.... LT4 Hot Cam... Forged Elgen Pistons Scat 9000 Crank Elgen 5.7" rods New Lifters w/ 1.6 Rockers and hardened Pushrods Super Ram Intake Hooker Headers and Y pipe into Gutted Cat with Monza Mufflers (WAY TO LOUD!!) Adj Regulator K&N Shift Kit High stall converter 160 termo, ZR1 Rims.... Red Calipers....Alpine head unit, Kenwood 6x9 4 ways, Polk DX 6 1/2 compnents, MTX 240 amp, Viper 550 alarm,
www.corvetteforum.net/c4/nomar116/
Old Nov 8, 2001 | 08:59 PM
crucial's Avatar
<font face="Verdana, Arial" size="2">Originally posted by Nomar116:
Paul
</font>
The revlimiter shoudl be set at around 10,000 RPM by GM. Dont ask me why they did this but it's normal, believe it or not!
As far as highway mode.. that's another feature GM chose to leave out. That's why it's set to come on at 255MPH. Lower that to a reasonable amount like 55-60 and also look for the RPM it's set to enable at and chage that to a reasonable amount also. (I have mine at 2000rpm).
1991 Z28 5.7 TPI
ZZ4 heads, ZZ4 cam, Harland Sharp roller rockers, Accel base, SLP siamesed runners, 52MM SLP Throttle Body, Hooker Headers, Flowmaster catback, MSD6A ignition, Home made ramair system, aluminum driveshaft, WC 5-speed etc
Old Nov 8, 2001 | 09:53 PM
Nomar116's Avatar
Well what is highway mode... and what about the cylinder volume.
A second question is what causes the egr code 32... in a setup like mine.
Paul
90 Red Convertible
100k running great
ZAINO!!!
LT1Formula
Oct 8, 2015 08:34 PM
jaridjohn
Oct 5, 2015 07:01 AM
