Comp swap from 89-92 to 88 possible??
Old Nov 11, 2001 | 01:46 AM
TZFBird's Avatar
Car: 1988 Firebird, 2000 GTP
Engine: 327
Axle/Gears: 9" posi, 4.11
I would like to use the winaldl software to run on my car, but I have an 88 TBI. What do I need to do in order to get this to work?
Thanks, Tyler
Old Nov 11, 2001 | 11:08 AM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Just plug in a 8746 ECM with custom prom w/o VATS.
Chronologically challenged. But still kicking!
'92 CAMARO RS
305 TBI 5/spd (now TPI)
B4C Alt.
Cam change:TRW 198/210 ,450/.460 114 LSA
Stock TBI manifolds
'85 IROC Ex.
14.94-92.00 mph
SPDC base and "350" Vortec coming soon!
'69 camaro-BB/Lenco,1050 dominators, /Pump Gas/no drugs 8.97-150+/3200lbs.
SoCal Thirdgen F-Bodies
Old Nov 11, 2001 | 12:34 PM
TZFBird's Avatar
Engine: 327
Sorry, but I have no idea what that means. I know nothing about this stuff. If you could get me any more info., it would be great. Is there any way for me to just go to a salvage yard and get this stuff for my car, or would that require a ton of new stuff? If I have to spend a lot of money on this, I will just forget it and figure things out the old way. But thanks for the help.
Old Nov 11, 2001 | 03:24 PM
JPrevost's Avatar
Car: 91 Red Sled
He just said you could plug in a new ecm. As in Unplug old ecm, plug in new ecm. You would need to get the VATS disabled. The VATS is that little resistor in the 89-92 ignition key. You've got e-mail
nuggie
Aug 25, 2015 01:27 PM
mz92274
Aug 25, 2015 08:47 AM
theurge
Aug 21, 2015 12:46 PM
aaron7
Exterior Parts Wanted
Aug 18, 2015 05:47 PM
