LINKED for the first time, then ECM died
Old Nov 13, 2001 | 05:56 PM
ryn28's Avatar
Car: 1986 Camaro Z-28
Engine: Chevy ZZ4
Transmission: Select Built 700R4
Axle/Gears: Moser Axles / 3.73 Richmond Gears
I got a new, rebuilt ecm from my mechanic to try and it linked on the second shot, with no fuss. Then I went to start the car and nothing. The ecm was smoked. With that cable, do I remove the cig. adapter right after it links or leave it in? My fan relay also died, noticed it driving home. Could that have happened at the same time or was it just a fluke?
On my old ecm I left it connected for a long time and it didn't do any damage. It also never linked with that ecm. I'm getting another rebuilt ecm from my mechanic this weekend. He's not charging me for these but I'd rather not blow up another one.
Old Nov 13, 2001 | 07:11 PM
lars92RS's Avatar
Car: '92 RS
Engine: In pieces
Transmission: Built 4L60
We ar gonna need a little more info on what ECM you have and which cable you used and which software.
-Lars
Old Nov 13, 2001 | 09:06 PM
ryn28's Avatar
Engine: Chevy ZZ4
Sorry about that, some of the info got "lost" somehow when I was writing it.
I'm using Craig's software with an AKM cable on a 1227165 ecm.
Old Nov 13, 2001 | 10:49 PM
leirch's Avatar
Have you tried linking to the ECM after the car is running? That may be the problem, that while its linked and not running its shorting it out somehow? That shouldn't be the case. It didn't matter in my case when I had the 165ecm.. and still doesn't even with the 730 ecm.
I'm using Diacom but that shouldn't matter either. Maybe there is something up with the cable? I don't know much about the cable so I'm not of much use.
Brendan
1987 IROC-Z L98,SR,EB 6085's,LPE 219/219 Cam, Crane 1.6RR, EB TPI Base, 58mm TB, Stock T5, 30lb SVO, AFPR, K&N, EB TES, Catco Cat, 3" Borla Cat-Back, Accel cap,rotor,distro/other crap, Aluminum DS, 94 Disk Rear, Adjustable Prop Valve, Precision 3.73 Gears, Weld in Sub-Frame Connectors, Hotchkis LCA's, KYB Shocks/Struts, Poly Bushings all over the place, Moog Upper/Lower Ball joints and Tie Rods ends/Idler Arm, Big stereo, 730SD Conversion.
To see the ROC, Check out the webpage Here
Old Nov 14, 2001 | 04:41 AM
Matt87GTA's Avatar
Car: 1987 Trans Am GTA
Engine: Miniram'd 383, 24X LS1 PCM
Transmission: TH700R4, 4200 stall
Axle/Gears: 9", 4.33:1
<font face="Verdana, Arial" size="2">Originally posted by ryn28:
With that cable, do I remove the cig. adapter right after it links or leave it in?</font>
I don't use the cigarette lighter power adapter at all. My laptop links up fine on lots of cars..... (until the battery goes low on the laptop..... grrrrrr).
1987 GTA L98 MD8
355, TFS Heads, LT4 Hot Cam
My GTA
The Minnesota F-body Club
eightsixseven
Dec 16, 2024 01:50 PM
mustangman65_79
Apr 14, 2017 05:37 PM
Andrew6.688
Dec 13, 2015 10:59 AM
