Z I F Instulation
Car: 78 Regal
Engine: 82 FBod LG4 305, 730 ECM
Transmission: M20
Axle/Gears: 4.10
If the wire length on the ZIF isn't long enough you'll have to make them longer with a header or anything else. As an example I use the excess of electrical gizmos like resistors and capacitors. The usual problem is that the ZIF physically hits the ESC filter so you have to overcome it by moving it higher than the base of the memcal.
Just get out the soldering iron, turn it to high, get the solder and flux and let it ROCK
Jason "TrickFlow" Zajac
JnJSpdShop@aol.com
JnJSpdShop@aol.com
ToplessRoc
Exterior Parts for Sale
Jan 31, 2009 07:35 PM
