WinBin and the .ecu file?
Old Nov 16, 2001 | 02:56 PM
gixxer92's Avatar
Car: 1986 IROC, 2017 Silverado
Engine: 7.0L, 6.2L
Transmission: Tremec Magnum, 8L80
Axle/Gears: 3:23, 3:55
Where do I get this file if I have the Bin.
Yes, I'm new to this.... Sorry
68 RS
86 IROC-Z
95 Z28
My Site
Old Nov 17, 2001 | 04:44 AM
Matt87GTA's Avatar
Car: 1987 Trans Am GTA
Engine: Miniram'd 383, 24X LS1 PCM
Transmission: TH700R4, 4200 stall
Axle/Gears: 9", 4.33:1
In the future, use the search function to find easy to find stuff like this - as well as questions that most assuredly have been asked by others in the past. Not flaming - just letting ya know that the search function is great and saves a lot of repeat questions and typing for all of us .
Here is a link to a WinBin .ecu file for the ARAP code ($6E).
http://www.area51.org.il/~zaphodb/gmecm/6Ev008.zip
I am not sure if that is the one you want, but it is one of the ones for the 165 ECM. If you aren't using the ARAP code as your base, I suggest you check it out as it is one of (if not the) most aggressive bin that GM made for MAF TPI engines and provides a good foundation to start with.... A lot of MAF guys (myself included) are using modified ARAP bins...
Hope that helps.......
1987 GTA L98 MD8
355, TFS Heads, LT4 Hot Cam
My GTA
The Minnesota F-body Club
InfernalVortex
Apr 20, 2021 11:31 AM
Rocket-Doc
Nov 14, 2015 02:08 PM
Jonas Earl
Sep 27, 2015 07:39 AM
MitcherNeaf
Sep 24, 2015 09:23 PM
80smetalfan
Sep 22, 2015 02:55 PM
