HELP, code 46 will not go away!
Old Oct 29, 2006 | 03:56 PM
Raiden's Avatar
I have a Craig Moates G1 addapter. I recenty burned a new bin and noticed my "service engine soon? light came on. I put my jumper in the ALDL unit and got no response. I changed my chip in the ZIF socket, no response.
Then, I put the orginal chip in without the addapter and I received a code 46 and a code 51. I unpluged the ECM and the negitive battery cable for 10 minutes. I then connected the ECM and battery cable. Now I get a code 46 which I think is a vatts code.
How do I clear this code or fix this problem?
Thank you for your help
Old Oct 29, 2006 | 04:35 PM
Raiden's Avatar
Well, I think I found the problem. I have another ECM, I pluged that in and my code was gone. Then, I connected the other ECM and the code was gone. I then put my Craig Moates addapter in with a chip. I then got a code 46. So either my chips are bad or my addapter is bad? I am thinking that is the addapter because my pocket programer 2 is recognizing my chips and burning/erasing them with no complications. I figured I will just send my addapter in to moates.
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
dusterbd
Sep 29, 2015 08:40 AM
