grr tuner pro..free version..help
Old Oct 29, 2006 | 10:33 AM
GTA's Avatar
GTA
Car: 1992 GTA
Engine: running
Transmission: working
Axle/Gears: both
HI all
Old Oct 29, 2006 | 11:21 AM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
You need a "burner" like Intronics Pocket Programmer to read the bin itself from the eprom. TunerPro allows you to modify the bin after you have read it off the eprom.
Old Oct 29, 2006 | 12:46 PM
DM91RS's Avatar
Car: 91 RS
You said that you have a burn1 from Craig? If so and you are using TP plug in the burn1 unit and click the icon at the top of TP that looks like a wire with a connector on it and it should say its searching for and then finding the unit.............or when using TP under tools go to preferences then ALDL/Emulation tab and check Detect hardware at startup.
See if that gets you anywhere..............
PS.... Craig also has software that comes with the burn1 that you can read and burn bins with.
Old Oct 29, 2006 | 01:11 PM
GTA's Avatar
GTA
Car: 1992 GTA
Engine: running
Axle/Gears: both
Thanks for the reply's
Old Oct 29, 2006 | 02:48 PM
Car: Death Mobile
Engine: 666 c.i.
Oops, I didn't notice the "burn 1". I can't comment on the differences. I think the Pocket Programmer can handle a greater variety of eproms. But if you are only interested in your own car, then it doesn't matter.
Also, if you want to "read" an AT29C256 Flash Prom, you really should read it as a 27C256 (which is what the ECM thinks it is).
Old Oct 29, 2006 | 06:15 PM
Craig Moates's Avatar
Car: 87 T/A
Engine: 441 SBC 12.5:1 0.680" Lift
Axle/Gears: 4.10 TruTrac Moser 9"
You've got everything you need, and it should all turn out just fine once you figure it out. There aren't any easier methods I don't think, what you have on your hands is about the easiest.
Old Oct 29, 2006 | 06:38 PM
Mangus's Avatar
Car: '89 Trans Am WS6
Transmission: T5WC
Axle/Gears: 3.08 posi
TunerPro Free does not interface with the BURN1. You need TunerPro RT or the BURN1 standalone software.
Old Oct 29, 2006 | 06:57 PM
DM91RS's Avatar
Car: 91 RS
Mark thanks for clearing that up on the TP as I forgot that I had TP RT running....... One gets so used to having it easy..........
tmellott89
Oct 14, 2015 02:06 PM
MitcherNeaf
Sep 24, 2015 09:23 PM
R13_Braz
Sep 18, 2015 05:00 PM
rubyred88
Sep 17, 2015 02:19 PM
85Special
Sep 3, 2015 04:21 PM
