A list of everyones' PROM equipment.
Old Dec 11, 2001 | 08:50 PM
MikeT 88IROC350's Avatar
Car: 1988 IROC-Z
Transmission: 700R4 w/TransGo
Axle/Gears: BW 9-bolt w/3.73s
I was just scanning some of posts and see that there are several "newbies" coming in to the wonderful world of chip burning for their vehicles. Most of them seem to want to know what equipment to buy.
I thought maybe we could make a post that shows what all of the current "burners" are using for chip burning. A brief, but inclusive list of everything that you use to test, tune, and burn chips for your ride.
I will start by showing what I am using:
Chip Burner: Pocket Programmer
Chip Eraser: none; borrow one at work.
Device Used: 27C128
Memcal: ADS with ZIF socket soldered in.
Editor: Tunercat $6E
Base Bin: ARAP, modified of course
Scan Tool: Ease Diagnostics, Personal Plus version for GM OBD I
Hopefully this list will give new folks an idea of the more popular equipment PROM burners are using.
If this is a bad idea, moderators please lock it.
Best ET 14.413 @95.57 without
pulling valve covers or manifolds.
Also with stock 2.77 rear end!!!
Old Dec 11, 2001 | 09:27 PM
SATURN5's Avatar
Car: 84 SVO
Engine: Volvo headed 2.3T
Transmission: WCT5
Axle/Gears: 8.8" 3.73
Heres my collection of goodies........
Computer: Dell Latitude XPi P90,32M
Chip Burner: BP Microsystems EP-1
Chip Eraser: borrow one at work.
Device Used: 27C256
Memcal: 749 Syclone,ZIF socket soldered in.
Editor: Promgrammer98 for SyTy
Base Bin: $58 AYBN4174
Scan Tool: Andy Whittaker's Freescan, 2 transistor cable
79 Chevy Malibu Cpe
305 TPI/700-R4,9 inch,3:50 Trac-Loc
Custom Twin Turbocharged,Intercooled,
'749 ECM, modified $58 code
currently in skunkworks
http://turbotpi.homestead.com/SATURN5.html
[This message has been edited by SATURN5 (edited December 11, 2001).]
Old Dec 11, 2001 | 10:44 PM
Brent's Avatar
Burner: Needhams EMP-10
Eraser: Datarase II
EPROMS: 2732A from Astro Marketing
Editor: Winbin, Tunercat
Scantool: MPSI-9000
Old Dec 11, 2001 | 10:53 PM
Ken73's Avatar
Car: 82 Corvette
Engine: 350 CrossFire
I've got a Compaq LTE 5400 - 150Mhz Pentium, 32mbs RAM. I've got the actual Compaq DC-cigarette lighter adapter for it (rather than a bumbling DC-AC adapter, then the accompanying AC-DC adapter, which I used to have on my old Dell setup.) I run WinALDL on it with the single transistor interface.
For a burner I've got a Needham's PB-10. It's the ISA card internal burner - unfortunately they don't make them anymore, but for just a few bucks more I believe you can get the Pocket Programmer, which I'd actually prefer nowadays.
Eraser is one I swiped from work from their days of making Novell boot PROM's. This thing erases probably 30 chips at once.
Chips are 2732A's, of assorted manufacture. Some are AMD's, which many people say to stay away from because they're too wide, but they're only too wide if you try to use the plastic carrier. I quit using mine and just slap the chip in directly, with the pins bent at a nice 90 degree angle. Press fits just fine every time. Bumps, wiggles.. nothing seems to dislodge them.
The base bin is one I got from a friend who had one "made" for our application, which is an '82-'84 Corvette with the CrossFire with the '7747 upgrade. It wasn't tuned worth a crap, but now I'm able to tweak and tune like crazy with the assistance of WinALDL and TunerCat. There's actually a file on DIY-EFI called "winaldlvefixer.xls" that does just what you think it does - plug the numbers from WinALDL into it, the numbers from TunerCat, and it gives you new numbers to put into TunerCat. It doesn't get it right the first time - not even the second. But it does get you closer and closer each time. In 10 chips I've managed to get my main fuel table so close to 128 across the board that I could spit on it. Most of my values are within the 126-130 range. I'm shooting for slightly higher numbers (128-130) in the lower KPa/load areas, and slightly lower numbers (126-128) in the higher KPa/load areas - a little lean on the cruise, and a little rich on the load/acceleration areas.
Ken
Old Dec 11, 2001 | 11:43 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
<font face="Verdana, Arial" size="2">Originally posted by MikeT 88IROC350:
Device Used: 27C128
</font>
For my car:
Chip burning: Pocket programmer
Editing: I have gone thru my code, and rewritten it so it's Source Code. So I use a hex editor to write in what I want where I want it.
Eproms: The ecm is modified so instead of a 2732, I now use a 27128, and have room to write stuff in it.
Going to be using Flash proms with it when I get done with the current vehicle changes.
For the study of ecms:
Tunercat, GMEPro, and some of my own software. Hex editor.
Eproms: 2732, 27128, 27256, 27512, and OBDII reflashing.
Depending on ecm, it's not in a car, but rather on my ecm bench, and run various scanners and scope on it.
All it means, is that once you get hooked don't be surprised. There is a really neat world of stuff in the ecms.
I use Diacom Plus, (used to use OTC 2000s), Direct scan. I have deal pending on a CAMS machine (obsolete dealer shop tool). New it cost $18K, looks like I'll get it for $100.
For a guy just starting out, a pocket programmer, Dataraser II, a few proms (holders if needed), a Digitial Volt Meter, and a stop watch are all you really need.
Developing the techniques using the basics are invaluable. Once you get clear on them things get much simplier,
Old Dec 12, 2001 | 12:23 AM
Bobalos's Avatar
Old P1, 133
DataMaster for 8D
GME Pro (think I am going to try TunerCat next)
TechTools Emulator
Needhams Prom burner @ work for EEPROMS, no more UV proms.
BW
Bobalos
www.r71camaro.homestead.com
r71chevy@earthlink.net
&lt;&gt;&lt;
Old Dec 12, 2001 | 02:31 AM
JPrevost's Avatar
Car: 91 Red Sled
Pocket programmer, IBM 755cx thinkpad, scanning software, UV eprom dataeraser II, about 20 2732a eproms (the a doesn't mean anything except programming voltage), a bunch of friends that let you play with their cars!
Old Dec 12, 2001 | 03:45 PM
JMatlock88's Avatar
Car: 1991 Formula
Engine: 355 DFI Superram w/ R-Trim
Transmission: Probuilt 700r4
This is extremely helpful. Many thanks!
Ford red 1991 Formula 350. ROH 16in wheels, 1998 Grey Leather, street/strip 700r4 2400 stall, EIBACH springs, Strut tower brace, Poly Bushings
3.73 SLP POSI, 26 spline Moser Axles, mid SLP cam, grear drive, SLP runners, 24# injectors, Taylor wires, Accel Coil, Accel Ignition, B&M Megashifter, K&N conical, AFPR, SLP 1 3/4 coated shorty headers, 3in cat, 3in. mandrel-bent single exhaust, flowmaster, TB air foil, 180 stat, SSM SFC's, SPOHN lower control arm adapters, custom burned prom, Hotchkis Lower control arms, Aluminum Driveshaft, ported upper and lower, q-logic kick panels.
Instant Messenger JMatlock88
https://www.thirdgen.org/messgboard/Forum12/HTML/005706.html
Old Dec 12, 2001 | 06:02 PM
Mojo's Avatar
Eraser: n/a
Device: AT29C256
Memcal: random V8 Camaro memcal with ZIF soldered in
Editor: Tunercat $8D
Scan Tool: Datamaster $8D
Cable: AKM
Old Dec 12, 2001 | 06:25 PM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
Ooo, the first "poll" on the DIY Prom Board. Well, since it IS related to prom burning, I will play along too.
Burner: Pocket Programmer with Windows software.
Eraser: Datarase II (collecting dust)
Proms: AT29C256
Bin Editor: Tunercat and TDF Editor to add new constants and tables.
Scan Tool: Diacom + (looking at developing own for SD cars)
Computers: 2 Notebooks and 1 Desktop.
Old Dec 12, 2001 | 07:26 PM
Lionsden's Avatar
ECM: 1227747
Chip Eraser: Datarase II
Device Used: 2732a
Editor: Tunercat
Scan Tool: Ease Diagnostics, Personal Plus version for GM OBD I and Winaldl
Dan
Old Dec 12, 2001 | 09:15 PM
Matt87GTA's Avatar
Car: 1987 Trans Am GTA
Engine: Miniram'd 383, 24X LS1 PCM
Transmission: TH700R4, 4200 stall
Axle/Gears: 9", 4.33:1
Laptop: Toshiba Satellite Pro 400CS Pentium 75 MHz (eh... cheap)
Scantool software: Craig Moates
Cable: AKM
EEPROMs: AT29C256ND 12PC
Burner: Intronix Pocket Programmer II
Bin Editor: TunerCat with $6E definition file (for ARAP-based MAF code)
1987 GTA L98 MD8
355, TFS Heads, LT4 Hot Cam
My GTA
The Minnesota F-body Club
Old Dec 13, 2001 | 09:57 AM
Allan's Avatar
Car: 1988 IROC-Z
Engine: 5.7L TPI
Axle/Gears: BW 2.77
Chip Burner: Just ordered the SPEP2 (parallel port, EPROM burner - not EEPROMs)
Chip Eraser: Datarase2 (I think ... the little one that can hold 4)
Device Used: 27C128
Memcal: Working on getting a few spares to work with
Editor: Still deciding. WinBin is neat. Looked at GMEPro (doesn't run right on XP). TunerCat looks pretty sweat, but I'm on a budget (who's not!)
Base Bin: ARAP (as suggested)
Scan Tool: none (yet) That's probably the next step.
Compaq Armada M700 PIII 500 laptop will be used for scanning once everything is set up.
IROCZONE
'88 Camaro IROC-Z 350 TPI
"Yea, though I walk through the valley of rice,
I shall fear no Turbo; for Torque art with me."
- Cullan Hooley
Old Dec 13, 2001 | 10:34 AM
86Red4+3's Avatar
Chip Burner: Homebuilt, have the magazine article prototye unit also (Steve Ciarcia design from 15 yrs back)
Chip Eraser: datarase II, no timer
Editor: Notepad
Base Bin: ftp://ftp.diy-efi.org/incoming/bub7943.zip
Scan Tool: Craig Moates software, slightly modified 2 transistor interface (blinkey light added)
O2 Sensor: DIY-WBO2
Jim
Red '86 4+3
Old Dec 19, 2001 | 03:31 PM
GRENDLE's Avatar
hey this thread is great for us beginners interested in prom burning, one question though, where can i buy most of this stuff, and does anyone make a "package deal" with everything i need? also aprox costs would be cool too. thanks
Old Dec 21, 2001 | 08:51 AM
mta227's Avatar
Compaq 5380 laptop with 32m, networked to a dual Pentium 90 server.
Burner : Pocket Programmer. with ver 1.13 windows software (works perfectly). I also have the newer software version but it has a few too many bugs for my taste.
Eraser : not applicable
Device : AT29C256 70ns (free samples!!)
PCM : 1227727
Memcal: Soldered 29C256 w/ modified 32 pin header adapter
Scan Tool: AutoXray
Data Logging : Still have a couple MAX232's collecting dust. May get time to put something together someday.
Editor : Wrote my own windows software since everything else available was quite unacceptable, IMHO.
Old Dec 22, 2001 | 03:31 AM
hairbear's Avatar
Car: 1997 SS 30th Anniversary
I also appreciate this info being a newby,an ignorant one at that. Like GRENDLE stated where would one go about getting the equipment(burners?,programmers?,etc.) I understand that the actual programming is something that you must learn thru trail and error and a alot of self education.
Old Dec 22, 2001 | 08:44 AM
Ral's Avatar
Ral
On the old board, there was a link at the top to TRAXION's prom intro. Dunno what happened to it but here's a link. It is a good read, and it has prices and suppliers for the equipment. https://www.thirdgen.org/newdesign/tech/promintro.shtml
Old Dec 22, 2001 | 09:45 PM
Dominic Sorresso's Avatar
Car: 92 ZR-1
Engine: LT-5
Transmission: ZF-6
Axle/Gears: SuperDana 44 4.10
Tunercat
Dell Inspiron 3000 Laptop
EASE OBD I Plus
Datateraser
Needham's EMP-10 Burner
Microsoft Excel
TI 2732A EPROM from Jameco
Started with TB CITY cal for 7747
Lots of help from Bruce, Carl Summers, and Ken Kelly
Performance Tech Center Dynojet Dyno
Old Dec 28, 2001 | 02:07 AM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
Computer: P2 300mhz with WinXP Pro
Programmer: Pocket Programmer2
Editor: Tunercat
Base Bin: SLP 91 Camaro 5 Speed Prom
(E)EPROMS: AT29C256 & 27C256
No scanning software/hardware yet, actually haven't burned a chip yet, I have all this stuff and need to try it out.
Gonna attempt to do this tomorrow afternoon.
Wish me luck.
Old Dec 28, 2001 | 06:25 PM
Matt87GTA's Avatar
Wish me luck.
Luck
Jorlain
Oct 8, 2015 01:57 AM
NastyEngines
Group Purchases
Sep 8, 2015 10:14 AM
Jk_Under
Sep 8, 2015 08:13 AM
Vassago
Convertibles
Sep 4, 2015 09:37 PM
