How can I use the stock o2 data to tune?
Old Nov 11, 2006 | 11:01 PM
Blazin4x4's Avatar
Car: 1988 Chevy silverado K5
Engine: 350 bored .030, crane cams hyd bluprint l-79 cam 447 lift 272 dur, camel hump heads port and polished 1.94 1.50, afterburner headers and y pipe, holley 670 cfm tbi, holley projection dual plane manifold, accel high pressure fuel pump, 3 inch exhaust
Transmission: 700 r4 with corvette servo and shift kit.
What would be rich or lean... Generally what is stoich?
Higher number means more air and fuel? Sorry for the newb questiong I'm still figuring this out.
Old Nov 11, 2006 | 11:22 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
Theoretically the switching point would be .450 volts or 450 Millivolts. Unfortunately we don't live in a perfect world and often times it varies widely.
Generally speaking if it is low it is leaner than 14.7:1 and higher is richer. With my GM heated O2 sensor, I see 30-40 millivolts at a wideband verified 15.9:1 A/F ratio, 470 millivolts @ 14.7:1, and about 900 millivolts @ 12.5:1. This is by no means what you would see at the same ratios as every vehicle is diffferent.
Old Nov 12, 2006 | 12:28 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
me and 87_TA did a scan run on my L98 that later was verified to be around 12.2 to 1 air/fuel. the scan run showed about 800-840 mv or so. i believe he said his car is running more in the 700's and is leaner than 12.2 to 1. but cars can differ
F.I. 57 Belair
Aug 23, 2021 01:09 AM
RedLeader289
May 28, 2019 01:47 PM
S10K20
Oct 7, 2015 06:45 PM
Zell1luk
Sep 29, 2015 10:36 AM
86White_T/A305
Sep 21, 2015 05:28 PM
