I'm missing some tables, how do I add them?
Old Nov 13, 2006 | 10:20 PM
bigburb93's Avatar
Car: 1998 Camaro Z28
Engine: 5.7 L
Transmission: Manual
I am missing these tables from my $E6 PCM Bin Definition file:
Startup AFR Correction Decay Rate
Closed Loop Disable Upper 02 threshold
Closed Loop Disable Lower 02 threshold
Closed Loop Enable Upper 02 threshold
Closed Loop Enable Lower 02 threshold
IAC Steps Vs. Air Flow
IAC Air Flow Vs. Coolant Temp (in drive)
IAC Air Flow Vs. Coolant Temp (in park)
Throttle Follower Gain vs. Coolant temp
Throttle Follower Gain vs. RPM
Startup AFR correction decay period Vs. cool temp
Startup AFR decay period correction vs. Air Flow
I found this out by looking at what tunercat has listed for the values in their file, and comparing it to the one that I got from tunerpro's website. Also, how do I edit the decelleration enleanment, i see a flag for when it is enabled, but i don't see anything for editing the enleanment values.
92firebirdguy
Sep 1, 2016 07:53 AM
tyeo098
Nov 30, 2015 06:27 PM
86CamaroDan
Sep 29, 2015 10:08 PM
BLK87Z
Sep 18, 2015 11:29 PM
gta892000
Sep 16, 2015 12:37 AM
