Hypertech with dip?
Old Jan 13, 2007 | 10:36 PM
cpullma2's Avatar
Car: 1987 Iroc Z28
Engine: 350 HSR
Axle/Gears: 3.27 Borg Warner 9bolt
Hypertech with dip?
Ok i am at wits end. I have a hyperchip with a dip socket and i tried to burn a chip for it, but i get constant ses light, and wont let me check codes. Ive tried arap bin with 6e, and abwn with 6e. Both did the same thing. When i put stock memcal back in ecm it runs fine and it lets me run codes, but nothing stored. Only thing i changed from stock was vats flag!!!! I dont know whats up! 1987 350 tpi with HSR now 165ecm What do u guys think?
Old Jan 13, 2007 | 11:13 PM
JP86SS's Avatar
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
Offset on the chip correct? (try stacking it)
Checksum either updated or disabled with AA?
Chip in backwards?
All the usual reasons.
Old Jan 14, 2007 | 12:10 AM
cpullma2's Avatar
Car: 1987 Iroc Z28
Engine: 350 HSR
I tryed using aa to disable it, that didnt work, chip was in correctly, but i am a noob and dont know what stacking is
Old Jan 14, 2007 | 07:50 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
The 6E mask is a 16KB BIN, which fits perfectly on a 128 Kb chip. If you used a 256Kb chip then the BIN needs to be doubled up (stacked), or burned into the top half of the chip. GM did this a lot.
Unless you get the SES blink at key-on, engine-off, the ECM is not running from the chip.
RBob.
InfernalVortex
Apr 20, 2021 11:31 AM
KO1
16
Oct 15, 2015 05:00 PM
Amillionoh7
Sep 26, 2015 09:45 AM
david068513
Sep 18, 2015 10:36 AM
NBrehm
Aug 25, 2015 11:49 PM
